Common engine failure signs?
#31
Ironman 140.6
Originally Posted by pcar964
No, Porsche was in the crapper building the air cooled cars, because the market didn't value the qualities those cars provided. Not due to any inherent design flaws
Clogged SAI's, valve guides, etc, etc.......
#32
Originally Posted by Ray S
Yep the air-cooled engines were all perfect......
#33
Ironman 140.6
Comparing wear items like valve guides, and the non-issue SAI problem, to unpredictable CATASTROPHIC engine failure, is just intellectually dishonest.
Yep, I'm sure Porsche designed them to wear out every 30,000 miles.
Trying to make it seem like an engine failure is just around the corner for every M96 is intellectually dishonest.
Boy Pcar, it's so out of character for you to come trolling around knocking the 996's......
You've always been our #1 fan!!
#34
Originally Posted by itorque
This is why I think that you cannot use the amount of bad motors on this forum to reflect reality. Many of us are on this site simply because we had bad motors so, IMHO, it is highly skewed in this direction.
#35
Originally Posted by swmrdrn
Your are absolutely correct. Technically this is known as a self selection bias and any conclusion derived from a sample of this nature is worthless.
#36
Like someone earlier said every car maker has some engine replacements. Heck look at the year Toyota has had recently with the big lawsuit over oil sludge and engine replacenment. I had engine replacement within 6 months of ownership anf 5k miles. Car has been a dream ever since the new one was installed. I cannot imagine driving anything else.
#39
#40
Originally Posted by dresler
ok, it was a stretch. you know, self-selection... hair on the palms....
#41
Ironman 140.6
I don't think every M96 engine will fail, I just can't imagine owning one when you simply don't know if it will fail. And by the way, I don't know anybody with valve guides wearing out at 30k miles, or even 60k miles, on a 993. My car consumes 1 quart per 1900 miles, so I guess I "dodged that bullet" .
It (the 996) is just a far less maintenance intensive vehicle. The 996 has much longer service intervals, less expensive parts, is easier to work on and has fewer little problem areas. All in a car that will leave a 993 begging for mercy (equal drivers of course) on any road course in the world.
I'm sure you'll disagree. However, even if you look at the worst case and my motor lets go (I've got two M96 motors with almost 12 years operation between them and I have not had any problems with them). I can plop a new motor in with a new warranty and be way ahead of a top end rebuild on your 993.....
Try not to......
#42
I'll tell you what, I'd be willing to bet you could take a 10 year cost of ownership for a 996 and a 993 (take out fuel, insurance, and tires) and you would be WAY ahead with the 996.
Try not to......
Try not to......
30,000 mile maintenance: Replace engine
60,000 mile maintenance: Replace engine and transmission
90,000 mile maintenance: Replace engine, transmission, and interior
Gotta hand it to those engineers, they really have simplified things
To your point, I would guess the running costs are slightly higher on the 993 (assuming the 996 doesn't grenade or a blow a gearbox), but not by much.
#43
#44
OK - lets talk look at a larger sample of M96 engines.
Let's look at all of the Boxster's covered by Warranty Direct, from'96, in the UK.
And let's look at Engine failures specifically:
http://www.reliabilityindex.co.uk/ma...8339010848601#
UK Porsche Boxster's have a failure rate of 20.69%
That's worse than Land Rover, Alfa, all the Japenese manufacturers, in fact they are 3rd last.
Of course, only people who think they are going to have engine failure sign up with warranty direct for their extended warranties.....
If you try to sign up your 996 to Warranty Direct in the US, for an extended warranty - they are no longer accepting new policies.
Of course, that's purely coincidental, nothing to do with paying out for lots of engine failures.
Or that fact that in the UK overall reliability index:
http://www.reliabilityindex.co.uk/ma...28339010848601
They are only passed by Jeep as having a worse reliability rating.
Of course, those UK drivers probably abuse their M96 engines in some way, so let's look at US drivers for the same Boxster model.
http://www.reliabilityindex.co.uk/ma...01&country=usa
Seems like the US cars have a 35.99% probability of failure when you look at engines specifically.
Pontiac, Plymouth and Land Rover are worse - not exactly a stat to be proud of!
And if you look at over all US reliability:
Only Volvo are worse.
Of course the fact that the US and UK numbers both show significant issues with engine failures, is purely coincidental.
The number of cars covered by warranty direct must be skewed in some way, to be comprised of a higher percentage of cars with troubled M96 engines....
Personally I've only had 2 engine failures with the M96, third one is a charm - well for the first 16,000 miles any way.
But I'm sure non of this is significant in any way.
#45
1)I just purchased an extended warrenty on my engine 3 months ago.
2)It's hard to understand the data you are presenting as it has no context.
