Make your 996 C2 handle like a GT3 RS, only $2.99!
#46
Originally Posted by BruceP
First, the CAI.
Then, the Plenum.
And now, the 'Sand Mod' is born.
I'm waiting until someone imports some ludicrously expensive, dyno tested sand from , like, German volcanoes or something. Then, I'm in.
Then, the Plenum.
#47
Originally Posted by Ray S
Much more!! But my solution doesn't add a ton of excess weight......
And it has the side benefit of improving (rather than diminishing) handling.
#48
Originally Posted by redridge
yes you are correct, in a way. Your aerokit reduced the top speed by 3mph...so it creates drag (more downforce), similar to adding weight (like the sandbag).
I sure hope nobody is taking the idea of adding weight in the trunk seriously. It's just about the dumbest idea I've heard yet. Adding unneeded weight is STUPID!
Jim
#50
Originally Posted by rountreed
But it is only $2.99
I'm instructing tomorrow. You can bet I'll be checking the trunk before we head out on the track. I'll also check for a plenum mod. I need to know if we have all that extra power and handling.
#51
WARNING: I spoke to the dealer who said to use only a Porsche approved sand of weight 0-S40. He also said the sandbag MUST BE properly bled per the TSB and to carefully observe the breakin period.
#52
Newbies Hospitality Director
Oh oh, I feel a "0-S40 versus a 15-S50" debate is eminent.
#55
As far as handling, We should go on a quick drive so that you can have a good look at the rear of my car.
#56
Originally Posted by Orient Express
Where is 60 lbs. a ton? In Munckinland?
#57
Ironman 140.6
I just tried my own version of this mod on my way home from Costco.
1) I picked up 3 cases of bottled water and put it in the front trunk.
2) I drove home on a tight twisty road by my house.
3) I calculated the weight of the water when I got home
By volume I had 52.5 liters of water in my front trunk. This works out to 13.869 gallons which weigh 115.74 lbs.
Did the nose feel hunkered down? You bet!! I also noticed significantly more understeer on the drive (a noticeable difference vs. driving the car w/the front empty). Not a good feeling.
If you are really serious about this "mod" as some sort of cure for perceived handling problems......good luck!!
#60
Ironman 140.6
Originally Posted by gota911
This would probably work too, but I not partial to the way it lifts the rear end of the car!
Did you "Hit it".....
