996 Forum 1999-2005
Make your 996 C2 handle like a GT3 RS, only $2.99!
Old 06-05-2007, 12:41 PM
Orient Express
Orient Express's Avatar
Default Make your 996 C2 handle like a GT3 RS, only $2.99!
I found an interesting handling enhancement for my 02 996 C2 the other day. Have you noticed that even with a M030 suspension, that the front of a C2 is a little "floaty" over irregular road surfaces?
I found the perfect cure.
The other day, I had to go get some supplies at Home Depot so I took the Porsche. One of the things that I had to get was a 60 pound sack of sand. I put that in the front luggage compartment as far forward as I could, and all of a sudden the car was much more stable at speed. Smoother as well.
Has anyone tried this and had good results? I think that I am gonna keep a bag of sand in the car from now on! And all it cost was $2.99 + tax ($84.97 CDN)
Old 06-05-2007, 12:46 PM
rountreed
rountreed's Avatar
Wow that should get things going! We have people here worried about saving a few pounds and you go and tell us to add some weight. I must admit though when I am on the autobahn and fully loaded with luggage the front does feel better, I hope this helps you get the thread going.
Old 06-05-2007, 12:57 PM
ArneeA
ArneeA's Avatar
If you buy the sacks of sand in bulk from one of those industrial companies, you'll get them for pennies on the dollar!
Old 06-05-2007, 01:04 PM
porschedog
porschedog's Avatar
I use 60 pounds of feathers, so I stil save weight.
Old 06-05-2007, 01:12 PM
sat40th911
sat40th911's Avatar
I have also noticed with the trunk empty, the car's front will float and oscilate at high speeds. With luggage, it is more stable. Maybe they designed it to have stuff in the front to put a little weight to add stability.
The Land Rover sport actually hangs iron balast at its four corners to improve stability (this months automobile mag). Go figure.
Old 06-05-2007, 01:17 PM
ZBlue996Kam
ZBlue996Kam's Avatar
Put a fuel cell in
Old 06-05-2007, 01:18 PM
himself
himself's Avatar
I didn't know the exchange rate was so favorable...
for Canada.
-td
Old 06-05-2007, 01:19 PM
NNH
NNH's Avatar
Porsche did exactly the same thing in the mid 1960s when they hung lumps of iron on the front corners on the SWB 911.
Old 06-05-2007, 01:42 PM
Ray S
Ironman 140.6
Ray S's Avatar
I predict Dell will be by soon.....
Old 06-05-2007, 03:50 PM
redridge
redridge's Avatar
put a more agressive lip...though its not 2.99
Old 06-05-2007, 03:54 PM
Tippy
Tippy's Avatar
I read it was lead
BruceP
BruceP's Avatar
First, the CAI.
Then, the Plenum.
And now, the 'Sand Mod' is born.
I'm waiting until someone imports some ludicrously expensive, dyno tested sand from , like, German volcanoes or something. Then, I'm in.
Old 06-05-2007, 04:02 PM
JimB
JimB's Avatar
It's not as silly as it sounds. All trailbraking does is shifts weight to the front of your car during turn-in. A little sand would do the same thing. Unfortunately, that's the only positive effect. It will hurt braking, accelleration, etc., etc.
Guys racing stock class 911s almost always have to add ballast to make weight. It's always a hot topic of discussion where to add it. Most think on the floor under or in front of the passenger seat is the best but a few swear by adding weight in the trunk.
Jim
Old 06-05-2007, 04:19 PM
Nicolaasdb
Nicolaasdb's Avatar
I put my camera equipment in the trunk (50lbs) and the handling was soo much more stable.....
Old 06-05-2007, 05:00 PM
Steven C.
Steven C.'s Avatar
I use bags of salt for my STUPID pool. Weights the car and potentially rusts it out for weight savings all at the same time. One stop shopping
Quick Reply: Make your 996 C2 handle like a GT3 RS, only $2.99!
