996 15" Brembo Gran Turismo
15" slotted rotor with massive 6 piston calipers. The calipers are a work of art they're so nice. You won't find a better brake system. The attention to detail, McLaren rotor hardware. The best Goodrich lines Pedal feel and confidence is way better. Plus when repeated hard braking there is no better kit on the market. Massive 15" rear rotors and 4 piston rear Monoblock rears. Bigger than most kits front setups.
I am an authorized Brembo dealer so I can get significant discounts. PM me if interested for best pricing. Go with Brembo the leader of Braking Technology.
Absolutely yellow, the Monoblocks are the only Brembos you can order in yellow. I would love to help someone do this kit on their 996. I can do almost 1k off on this kit. There is no extra charge for yellow and your choice of slotted or drilled. I can also do the 14" for less. 15" kits give you better leverage and better cooling because of the bigger surface area. They do give up 1-2lbs of unsprung weight to the 14" kits but they're so worth it. These look so impressive. All I ask is that you take pics.
