996 Forum 1999-2005
Chads Mod thread: The info edition
Old 12-11-2007, 01:46 PM
Chads996
Chads996's Avatar
Default Chads Mod thread: The info edition
The intent of this thread: To offer helpful info to those out there who would like to modify and/or repair their car. Besides, this might be fun too...
PLEASE NOTE - I offer this information as a hobbyist to another. Please use caution and follow all safety measures when working on your own vehicle.
This thread will be updated as I install new modifications to the car.
The Car: 1999 Porsche 996 Carrera 2
Picked up with 28,500 on the odo.
3rd documented owner
Aftermarket mods by PO: GHL Exhaust, 19" iForged wheels, Bilstein PSS9 suspension.
Factory Options:
09991 EXCLUSIVE OPTIONS (manufactured from the exclusive-program)
CO2 - CATALYTIC CONVERTER
XAA - FACTORY INSTALLED AEROKIT CUP
XRL - 18" SPORTDESIGN WHEEL
220 - LOCKING DIFFERENTIAL 40 %
222 - TRACTION CONTROL SYSTEM
224 - AUTOMATIC LIMITED SLIP DIFFERENTIAL
236 - 18" TIRES
375 - SPORTSEAT, BACKREST SHELL, LEFT
378 - COMBINATION SEAT, RIGHT, ADJUSTABLE
424 - CD COMPARTMENT
436 - 3-SPOKE AIRBAG STEERING WHEEL
652 - DELETE SUNROOF
983 - SEAT COVERS FRONT, LEATHER
Car as delivered:
Old 12-11-2007, 01:52 PM
Chads996
Chads996's Avatar
Default UPDATE#1: 12/11/07
Factory GT3 Wheels
iForged wheels have been sold. I purchased a set of factory GT3 wheels from a very nice Doctor from LA. Upon speaking to a local metallurgist, I got the wheels powder coated black.
Please note: If you wish to do powder coating to aluminum alloy wheels, please consult with a certified metallurgist first. There are different alloys and ways to produce wheels. Each metal has different characteristics and knowing the proper information before you start will save much cash and headaches later.
Powder Coater info: the group I used is located in Cumming, GA and is called Professional Cryogenic Metallurgy & Coatings. No affiliation, just one serious happy customer. Very reasonable, the powder work cost $260 for the set.
website: http://www.procryo.com/
The results:
On the car:
Old 12-11-2007, 02:23 PM
Chads996
Chads996's Avatar
Default UPDATE#2: 12/11/07
Exhaust Tip upgrade:
Moving forward. From the get-go, I hated the GHL exhaust tips on the car. the stubby look to them made them look like an after thought.
I purchased black powder coated Schnell tips from VertexAuto. Had to wait a bit for them as they were out of stock, but the results were not bad. I think I will be shooting for the larger Tequipment tips in the future.
Results are....ok. they do look small at certain angles. Be 100% better then the existing ones.
Lip Spoiler install:
Purchased from Suncoast Porsche
Parts ordered / used:
Lip Spoiler (Part #996-505-986-G2X) - Primered
Plastic Rivets (part # 999-507-427-40) - screw in type
3M Body Panel tape (part# 000-043-206-04)
Rattle can - semi gloss black paint
Please note - there are two lip spoilers available for the car. The one noted above is the Motorsports lip. Both still need to be slightly modified in order to be fitted.
To fit the lip do the following:
1. Carefully remove existing lip by pulling the expanding rivets. (save these, they could be of some use later)
2. Using the old lip as a template, redrill the rivet holes on the new lip. Use the center as a starting point as both line up.
3. Prime (touch-up) and paint the new spoiler.
4. Add a bit more 3M adhesive tape to the new spoiler and carefully...slowly, install it. NOTE: you may need to trim away portions of the inside in order to get the spoiler to bend. Doing so will not harm it. Just be careful how much you take away.
The fitted spoiler:
GT3 Console Delete (A MUST for tall guys):
Parts Needed:
GT3 Console - (Part# 986-552-113-02-A10)
Black shifter Trim piece - (Part# 986-552-241-02-A03)
To install, simply remove the existing storage compartment and install the new parts. It is VERY simple and easy to do. The result is quite striking, IMO.
GT3 Console installed:
Old 12-11-2007, 02:27 PM
Chads996
Chads996's Avatar
Default UPDATE#3: 12/11/07
Toddler Seat
Every now and again, I need to pick up our 2yr old from Day care. After hunting and searching, I finally found the perfect seat. The Britax Parkway seat is the PERFECT fit. It is the one recommended on Rennlist and fits great. I found mine on Amazon.com for $69.99. A great price for this seat.
To install: Remove the bottom seat cushion (velcroed to the body carpet). Then adjust the seat for your child. Please note - the weight specifications on the seat and how that applies to your child.
Seat installed:
Old 12-11-2007, 02:34 PM
Chads996
Chads996's Avatar
New stuff coming: GT3 Sways, x51 oiling kit, short-shift and a intake mod. Stay tuned. As I progress on the modifications, I will be updating the thread with DIY's, part numbers and how-to's.
C.
Old 12-11-2007, 07:44 PM
Holger B
Holger B's Avatar
Looking good!
Can't be too many cars with the sunroof delete. Wish I ordered my '99 that way (I was smart enough to get the TC/LSD, though).
Old 12-11-2007, 09:00 PM
Born On 911
Born On 911's Avatar
Thumbs up
nice work Chad.
sorry for the dumb question, but how does the console delete benefit tall drivers?
Old 12-11-2007, 09:02 PM
Chads996
Chads996's Avatar
Originally Posted by Born On 911
nice work Chad.
Not a dumb question at all....Leg room, my friend. Leg room. My leg would hit the console. By removing it, your leg is more free in the cabin. Much more comfortable.
Highly recommended for taller folks.
C.
Old 12-11-2007, 09:09 PM
ls911
ls911's Avatar
Looks great in white, excellent work, love the wheels. How do you like you exhaust sound, is it only GHL mufflers?
Old 12-11-2007, 09:11 PM
Chads996
Chads996's Avatar
I like GHL's ok. Not bad, nice and growly but mild all the same. I had PSE on my last 996. LOVED THAT. Will likely run muffler bypass for track events.
C.
Old 12-11-2007, 10:56 PM
vwrado
vwrado's Avatar
Very nice car Chads, love the aero kit!
It seems that your tips are sagging kind of low. From my past experience of playing around with muffler and tip fitment, I bet you can move the muffler up to snuggly fit those tip under that bumper.
Old 12-12-2007, 11:11 AM
hwk72
hwk72's Avatar
C.
+1 - only way I (6'6'') can properly make heel and toe in the car.
Old 12-12-2007, 12:11 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Man, I HATE saggy tips!
Old 12-12-2007, 04:02 PM
insite
insite's Avatar
looking great, chad! PM me your email addy so we can hit the track after Xmas.
Old 12-13-2007, 12:06 PM
Zoolander
Zoolander's Avatar
Chad- Your car is really really nice. If you ever sell it let me know.
Quick Reply: Chads Mod thread: The info edition
