Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 01-12-2008, 04:23 PM   #1
DeAd-EyE
By The Power Of Greyskull
DeAd-EyE's Avatar
Default Garage Door Opener into a 996
Has anyone tried putting an opener for one of those oldskool automatic garages in their 996? I'm refering of course to the ones that need remotes with a specific code in order to open them (usually you open them up, trip the PIN switches to the right code to program it).
I'm thinking of taking one appart, wiring a porsche switch to it and then putting the whole thing under the center console or maybe in the dash if there is enough room.
Any thoughts or alternatives?
"Always use protection when engaging in viscous coupling"
Daily: '11 Mazda 2 - Tow Vehicle Extraordinaire
Wife: '99 Carrera - It's Stock...ish
Girlfriend: '93 Mazda RX-7 - Powered By Dorito's On A Stick
Motorcycle:'06 Suzuki GSX-R600 - Racing in SOAR 2012 #46
DeAd-EyE is offline   Reply With Quote
Old 01-12-2008, 05:00 PM   #2
tooloud10
tooloud10's Avatar
jrschmidt11 SlavishShrimp SlavishShrimp
You could just get one of the "headlight-flasher" models. I've heard this one works just fine:
http://www.f2ptechnologies.com/
tooloud10 is offline   Reply With Quote
Old 01-12-2008, 05:15 PM   #3
gota911
Newbies Hospitality Director
gota911's Avatar
Omar, you've been around here long enough to know many of us have done that.
You can just slide a plastic spatula behind the "horseshoe" and it should pop out. I usually start at the top corner (left or right), and once the top is loose, I move the spatula down about 2/3 of the way to the bottom and pry that part out. Repeat the process on the other side.
For instructions on wiring your Garage Door Opener to the middle three spades on the switch, check out Kirby's DIY with pics.
http://gallery.rennlist.com/gallery/albur29
The Targa Shade switch is part # 996-613-119-10-A05. (see pic#1)
Just to clarify, you don't HAVE to hard wire for the opener to work, but you DO have to tap into the existing wiring to get the switch to illuminate when you turn the car lights on.
Illumination Wiring - On the Windshield Wiper Rheostat switch (or another illuminated switch), look for a blue wire that has red hash marks on it (not a red stripe up the side of the wire). That is a positive (+) line for the icon lighting. Then find a brown wire (ground wire) on the switch, which is the negative (-) wire. Those are your 2 leads to tap into.
Illuminating the Switch - The 2 outside vertical spades are the correct ones to use for switch illumination and they will work either in parking or headlight mode. Pic #1 actually shows the Shade switch up side down, and it looks like open/closed garage doors. I installed the switch on the left side of my horseshoe so the switch "bump" and closed garage door icon are on the left, and the open garage door icon on the right. All you have to remember is that the positive (+) lead is on the closed garage door side of the switch (the side with the bump) and the negative (-) lead is on the open garage door side of the switch (the flat side).
Here is how I wired my garage door opener. Open you garage door remote and turn it over to the side opposit of the buttons. Use a paperclip to touch two connections to see if the door opens. Once you find those two soldered points, that is where you want to attache your wires. (See pic #2.)
Then I ran the wires from the switch (in the horseshoe) toward the front of the car. I then connected the wires from the garage door opener to those wires and clipped the opener under the dash. (Pics #3 - #6.)
I put the opener in that location so I can easily change the battery and can remove the opener easily when I sell the car. This cut down the range of the opener because it is below the dash, but I can still open the door as I am pulling into the driveway, so it is not an issue.
Tim K.
"Lurking About" no more!
Mods: Sharkwerks Center Muffler by-pass pipes | PSE | Ti Lug Bolts | Porsche Short Shifter
gota911 is offline   Reply With Quote
Old 01-12-2008, 05:18 PM   #4
DeAd-EyE
DeAd-EyE's Avatar
^....................niceeeee Tim.
btw, how's the blue interior holding up? Do you find it gets tiring at all?
Old 01-12-2008, 06:02 PM   #5
Jon996
Jon996's Avatar
Tim--this might be a dumb question, but it will probably not be my last . . . Do you think the switch that you have would also work in the center console, where I have two blanks behind the ashtray?
Thanks,
jon
Jon996 is offline   Reply With Quote
Old 01-12-2008, 06:19 PM   #6
Eric - Plug Guy
Lifetime Member
Eric - Plug Guy's Avatar
I have mine the same way with targa switch, but my power is tapped to the fuse and then the unit is up front in the battery compartment.
I also did this in an earlier 996 and used the oval plate beside headlight switch. Drilled two small holes in it, one for a pushbutton, other for LED. Worked like a charm.
Eric
Chief Plug Guy
BumperPlugs.com
2009 Turbo Cab
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric - Plug Guy is offline   Reply With Quote
Old 01-12-2008, 07:31 PM   #7
Kims996Cab
Kims996Cab's Avatar
I took the easy, clean way, and wired it so that the 12 VDC flash pulse (for flashing headlights) supplied voltage to trigger my opener .... also, by happy coincidence, 12 VDC powered. Only wiring is in the trunk, and directions are found in a number of P-car forums.
Kim
2000 Cab
Black Metallic / Graphite Grey
Kims996Cab is offline   Reply With Quote
Old 01-12-2008, 07:59 PM   #8
gota911
gota911's Avatar
Omar,
My interior is Graphite Gray with deviating Metropol Blue carpet. I like the contrast because it makes the interior a little darker. When I see a pic of an interior that is all Graphite Gray, I am always surprised at how light the interior is. I have not tired of it at all. In fact, if I ever get a 997 it will be Carrara White with Sea Blue interior. Here are a couple of pics of the interior.
Tim K.
Old 01-12-2008, 08:01 PM   #9
gota911
gota911's Avatar
Quote:
Thanks,
jon
Jon, yes it will work in the rear center console. All of these types of switches are the same size.
Tim K.
Old 01-12-2008, 08:23 PM   #10
rdstemler
User
There is a white Turbo with blue interior and deviating stitching at my dealership. You are correct! It is very good looking!
rdstemler is offline   Reply With Quote
Old 01-13-2008, 08:34 AM   #11
Bruce AJ
hijack... Tim, When you use your TomTom, how do you power it, the supplied power cord from the lighter socket?
Bruce
Bruce AJ is offline   Reply With Quote
Old 01-13-2008, 09:03 AM   #12
Dutchie in NC
Dutchie in NC's Avatar
Quote:
Bruce
I hardwired my Nuvi, so you don't have to use the power cord via the cig lighter... would think that you can do the same for the TomTom.
I pretty much followed these directions:
http://www.drumart.com/nuvi/
The only thing I did different, is that I did not use the fuse box to hardwire, but used the phone cables behind the console. This is the same cable a lot of us have used to hardwire radar detectors, i.e., have used the same cable for my Nuvi ansd Escort hardwire. See directions in this thread I posted last year for hardwiring the Escort:
http://forums.rennlist.com/rennforum...d.php?t=335015
Hope this helps.
2007 997S Basalt Black... in the garage
2003 996 Cab Seal Grey... sold
Dutchie in NC is offline   Reply With Quote
Old 01-13-2008, 09:43 AM   #13
gota911
gota911's Avatar
Bruce
Bruce, yes I use the cigarette lighter power cord. I removed the power cord when I took that pic. I was thinking of doing the mod that Dutchie mentioned, but since my 996 will be gone in May (lease end) I decided not to do the mod.
Tim K.
Old 01-13-2008, 11:37 AM   #14
Botsy67
Botsy67's Avatar
I did the same "Garage door" opener following Tim's exact description above and it worked great, Thanks Tim... I like this way bc I can put everything back to stock including the garage door remote in case we move again to a diferent house. I had to get a new "Batwing" w/ blank switches and place the "Targa" switch there since I used up the other 2 in the "horse-shoe". The interior looks a lot cleaner with this Mod.
Hey Tim, I have the same interior color as your car w/ the same "comfort seats" too but your car is 4 yrs newer than mine
-Bao
RL: 060430-3521
- '00 Porsche 996 C2 Cab 6 Sp (Baby), Midnight Blue Metallic/Gray, GT3 Aero-kit, GT3 wheels, Hardtop, Nav/V1-hardwire, Clear sides, Alu Gauge/Pedals, TechArt Sport Exhaust, Spoiler/Cooling-Mod/Garage-door -switches, Third radiator.
- '01 BMW 325i (Daily Driver), Black/Sand, Tip
Botsy67 is offline   Reply With Quote
Old 01-13-2008, 01:03 PM   #15
RF5BPilot
RF5BPilot's Avatar
For those who don't want to do the soldering themselves, Ebay offers a solution. I know it has been sold with the targa switch that looks a bit more like a garage door.
http://cgi.ebay.com/ebaymotors/PORSC...2em118Q2el1247
'03 996 Cab; Escort SRX, PSE, PDQ, RSVP; rf5b.com
RF5BPilot is offline   Reply With Quote
Tags
996, 99661311910a05, 996targa, dash, door, garage, icon, mod, opener, porsche, porsche996targa, remote, switch, targa, top
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
