Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 01-19-2008, 03:46 AM   #1
susansez2luv
New User
Default oil drain plug stripped
Well I just attempted my first oil change on my 99 996 Cab. Tried to use the piece of crap hex that comes with the car tool kit. It looked stripped and so did the insertion hole on the plug. Yep stripped for sure. Now I need to know how to get the plug out and a cheap non dealer site to buy a new plug.............. Help, running on black sludge in California.
susansez2luv is offline   Reply With Quote
Old 01-19-2008, 08:08 AM   #2
ls911
User
ls911's Avatar
Sounds to me like it needs to be tapped out of there. If you don't want to mess with that, go to a good indi or dealer. You should be able to get an accurate estimate for the plug removal, replacement and an oil change. Should not be that expensive and worth it since they can work on it via a lift and will have the tools needed.
The only other thing I can think of is a full engine replacement
ls911 is offline   Reply With Quote
Old 01-19-2008, 08:16 AM   #3
Robin 993DX
Lifetime Member
Robin 993DX's Avatar
Always use the right tools, if you want to start DIY at least buy a set of Sears craftsman tool combo sets. If you work on them enough you can upgrade to Snapons... like the set I have :P
That's probably one of the worse bolt you can stripp. I think the only thing you can do now is to use a reverse tap, basically drill a hole and then screw in the reverse tap and try to get that bolt out. You wouldn't need to worry about the metal scrap since all the oil will flush it out.
Try pelicanparts.com for the part, or just your local stealer.
Robin
Rennlist Lifetime Member 990415-1116
Rennlist 2nd Member 020204-3360
Rennlist 3rd Member 020215-3380
(Help support Rennlist, you can have more than one membership)
12 BMW X5M (My family truckster)
06 Cayenne S Titanium Edition (RED!!!) (Wife's family truckster)
02 Ferrari 360 Spider (Drama queen)
00 BMW 328i (Wife's beater car)
99 996DX4 (No frills Carrera 4 coupe daily beater)
96 993DX (2 wheel drive Carrera Coupe) SOLD!
http://www.p-car.com
Robin 993DX is offline   Reply With Quote
Old 01-19-2008, 08:50 AM   #4
steve germany
steve germany's Avatar
$4.50 at Pelican
http://www.pelicanparts.com/cgi-bin/...07-197-01-M260
To get it out yourself stop by Sears and pick up a set of the metric stubby easy-outs. They are reverse thread bolts/cutters. As you twist them in to the stripped hole they will increase torque in the correct direction to remove the plug. Don't forget a new washer and a rule of hand for the plug is finger tight and then 1/4 more. Better to use a torque wrench though...
Back home in Germany 5 miles from Weissach!
Black Hole Desert Storm Vet
steve germany is offline   Reply With Quote
Old 01-19-2008, 09:39 AM   #5
wxseed
User
wxseed's Avatar
it happens more than people think, if you aren't comfortable doing it yourself go to a dealer and pay the $200 they will want, don't do what robyn993 said because if you drill through and can't get the bolt out, you no longer have a car you can drive ...
try this link;
http://www.renntech.org/forums/index...=3308&hl=sears
btw a new drain plug and washer from a dealer is about $6.00
worst case if you really mess up is that you have to remove and replace the oil pan. $135.00 held on with 13 bolts and porsche sealant ......
and buy good tools, you're working on a $100K car ....
wxseed is offline   Reply With Quote
Old 01-19-2008, 10:04 AM   #6
LVDell
LVDell's Avatar
wxseed, I was just about to comment to this thread and reference my thread over on renntech (from 3.5 years ago!) and you beat me to it! GREAT FIND!!!!
It's very easy to strip that plug. Not to worry, get the proper tools as stated, get a new drain plug, and be on your way to DIY euphoria
Cheers,
Dell
LVDell is offline   Reply With Quote
Old 01-19-2008, 10:22 AM   #7
Botsy67
Botsy67's Avatar
This is a great thread, thanks Dell for sharing your way-out of this tough situation. I saved all your pics on Renntech for reference. I always wonder how to deal with this if that happens on my P-car. Cheers.
-Bao
RL: 060430-3521
- '00 Porsche 996 C2 Cab 6 Sp (Baby), Midnight Blue Metallic/Gray, GT3 Aero-kit, GT3 wheels, Hardtop, Nav/V1-hardwire, Clear sides, Alu Gauge/Pedals, TechArt Sport Exhaust, Spoiler/Cooling-Mod/Garage-door -switches, Third radiator.
- '01 BMW 325i (Daily Driver), Black/Sand, Tip
Botsy67 is offline   Reply With Quote
Old 01-19-2008, 10:24 AM   #8
Tippy
Tippy's Avatar
If you can get a BIG set of channel locks on the outer diameter of the plug, it should grip enough to get it out. Clamp on to it as hard as possible. You dont want to slip on this method either, makes it harder the next round. (Cant remember if there is anything preventing this from happening like casting of the oil pan interfering with getting the channel locks around the plug).
Or, get the right size allen wrench (preferably a socket allen) and beat it deeper into the plug with a large ball peen, sometimes it will work.
Thirdly, stripped bad enough, you can use a mm bigger wrench or possibly a SAE size that will fit tighter than the original size.
Cory
- 1987 Carrera 3.2 w/single turbo (T60-1/0.85 A/R) Guards Red/Black 427 rear wheel hp/2750 lbs. - granny shifting and steet tire 1/4 mile = 124 MPH @ 12.4
She's alive!!!! 2.5 years down for a "money shift" no longer......
Tippy is offline   Reply With Quote
Old 01-19-2008, 10:25 AM   #9
LVDell
LVDell's Avatar
Very welcome Bao!
I remember how frustrating it was when I tried to do my first oil change only to discover a stripped drain plug. By the way, the CAB (like I said in your other thread) looks fantastic! Identical to mine (except the color of course).
Cheers,
Dell
Tags
996, change, drail, drain, indian, nut, oil, open, plug, porsche, replacement, strip, stripped, turbocharger, ways
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
