996 Forum 1999-2005
How do I tell if my turbo-twists are "hollow"?
Old 05-24-2008, 11:08 PM
PJorgen
PJorgen's Avatar
Default How do I tell if my turbo-twists are "hollow"?
OK, car is an '02 C4S with what I believe are stock turbo-twist wheels, but I'm not the orignal owner so can't be sure. So anyway I'm replacing the rear pads today and got to looking at the wheels from the back. The spokes have deep grooves in the back, presumably to reduce the wieght.
Does this mean they're the "hollow" spoke wheels?
Old 05-24-2008, 11:09 PM
TT Surgeon
TT Surgeon's Avatar
Screw in valve stems, but the only holows on c4s cars were the sport technos, all the rest are solid. The grooves you describe are a trademark of solids I believe.
Old 05-25-2008, 01:42 AM
Robin 993DX
Lifetime Member
Robin 993DX's Avatar
Two ways to tell, (1) Metal valve stem = hollow spoke, rubber = solid (2). Grab the spokes, if you feel ribs in the back of the spokes then it is solid, if feel smooth then it is hollow spoke.
Old 05-25-2008, 03:28 AM
Tool Pants
Tool Pants's Avatar
With hollow spoke the back of the spokes are smooth. Groves means solid spokes.
Old 05-25-2008, 03:02 PM
Palting
Palting's Avatar
All the above. Plus, the C4S comes standard with the solid spokes.
Old 05-25-2008, 04:59 PM
PJorgen
PJorgen's Avatar
OK, pretty definitve answers - I've got solid spokes.
Thanks!
Old 05-25-2008, 05:09 PM
Malakas
Malakas's Avatar
Ribs in the back. Solids here too
Old 05-25-2008, 06:03 PM
redridge
redridge's Avatar
hollows... bend easily, be happy you have solids!
Old 05-25-2008, 06:25 PM
pongobaz
pongobaz's Avatar
...uh, I don't think so. I have a set of both; the solids(for winter use) that came with the car and a set of hollows (for summer) bought off a 996 TT. My rear solids have bent, but not the hollows.
Old 05-26-2008, 12:01 AM
PJorgen
PJorgen's Avatar
Anyone know the weight difference between solids and hollows?
Old 05-26-2008, 02:31 AM
redridge
redridge's Avatar
996tt mostly use hollows... however the 996gt2 use solids.... they are stronger and heavier! In NY/NJ area winter is def harsher than driving in the summer.
Old 05-26-2008, 10:41 AM
jumper5836
jumper5836's Avatar
The 2001 996 TT came with solids.
Factory 996 Turbo Hollows
8x18" at 22 lbs 2oz
11x18" at 26 lbs 5 oz
Factory 996 Turbo Solids
8x18" at 26 lbs 2 oz
11x18" at 31 lbs 6 oz
Factory 996 GT2 wheels (earlier years, Turbo Solids):
8.5x18" at 28lbs 11 oz
12x18" at 33 lbs 0 oz
Factory 996 GT2 wheels (later years, GT3 style)
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
and for some comparison
Factory 996 GT3 wheels
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
Factory Carrera S 997
8.0 x 19 - 22 lbs. 4 oz.
11.0 x 19 - 27 lbs. 12 oz.
Old 05-27-2008, 01:23 PM
auto-xr
auto-xr's Avatar
http://www.944racing.de/reload.php?u...elweights.html
Good site w/part numbers.
Quick Reply: How do I tell if my turbo-twists are "hollow"?
