996 Forum 1999-2005
GROUP BUY-SCHILD LID LINERS
Old 06-24-2008, 04:14 PM
Lidliner
Basic Sponsor
Lidliner's Avatar
Default GROUP BUY-SCHILD LID LINERS
Hello Rennlist members,
We are back as a sponsor to the rennlist forum and to reintroduce ourselves we are offering a Group Buy to all registered members. This is our first opportunity to be offering a GB to rennlist members and have all models available. The Group Buy will run from today to July 7th.
When we reach 30 interested members we will extend a 30% discount.
This reduces 996,997 and Cayman(S) Schild liners to $139.30 from orig. $199
The same discount will be extended for all Boxster, $299 to $209. (1997-2008)- and 911 models $169 to $118. (1974-1998)
Das Schild lid liners protect your 911, Boxster and Cayman trunk lids from damage caused by oversized and misplaced cargo. Here are a few recent quotes from our customers.
“Installed in two minutes and a perfect fit. Thanks!”
“Just installed mine. Perfect fit & match. Thanks!”
“This really is a brilliant product that could easily pass for OEM.”
“This should be OEM--suggest they offer Porsche a group buy...
“I second that!”
“As many others have noted, this is a very well made product and a snap to install (pun intended).”
“Outstanding product, easy installation, thanks again! What a great value!”
Visit http://www.dasschild.com/testimonials.htm for more info.
On July 7th we will adjust our prices online to reflect the discount at which time you will be asked to supply your username to order(S&H is $21.95 for US & Canada, $39 for Int'l). We look forward to any questions or concerns and are glad to be back as a sponsor-We will be monitoring all applicable boards as frequently as possible. Thank you! Enjoy the holiday-made in the US
Jim
Lid Liner Corp.
jim@lidliner.com
800-933-3375
813-371-0161
Old 06-24-2008, 04:18 PM
Ubermensch
Ubermensch's Avatar
What is the liner made of? I see that it's foam and then some other material, but it's not clear.
Old 06-24-2008, 04:33 PM
Ray S
Ironman 140.6
Ray S's Avatar
Count me in for a Boxster rear only. By my calculations the GB price is $97 right?
Old 06-24-2008, 05:38 PM
Lidliner
Basic Sponsor
Lidliner's Avatar
The 996/986 is a factory matching ABS black plastic. The foam back side is being replaced with neoprene at installations points to prevent any metal, the bracing, on plastic contact.
Yes, rear only for 986 or 987 is $97 after discount
Old 06-25-2008, 01:53 PM
Delbox
Delbox's Avatar
I'd be interested in a 996 TT lid liner; I'm in the UK.
Del
Old 06-25-2008, 02:11 PM
Rob in WA
Cap'n Insane the Engorged
Rob in WA's Avatar
Interested ........
Old 06-25-2008, 02:15 PM
Lidliner
Basic Sponsor
Lidliner's Avatar
Default Pictures as requested
This quote from a club member post includes pictures and details of the installation process.
"In order to give a full explanation of the product and how to install it, I ordered from Das Schild and photographed the installation. Before someone asks - "How much does it weigh" - let me answer that I did not put it on the scale but I would be surprised if it weighed more than 5-8oz at best. There is absolutely no issue with weight with this item, it doesn't weigh down your trunk lid etc, it is very light, yet plenty sturdy!
I took some very detailed photos of the Das Schild and of the installation. Let's have a look at those photos shall we!
First the item arrives wrapped in plastic inside its own Schild box as shown in this photo:
I unwrapped the item and laid it out on the floor to get pictures of both sides, first a picture of the side that you will see whenever opening your hood followed by a picture of the backside.
Notice in the picture above that there are 10 pins already installed in the Das Schild that will attach to the underside of the hood. The next photo shows the backside of the item with the foam padding designed to stop any rattling between the schild and the metal hood. This foam will compress when the item is installed.
The photo also shows the 10 pins and I decided to take a close up picture so the pins themselves could be seen in more detail. They are the kind that are easy to push in, but difficult to pull back out, the press-fit type.
Installation is incredibly easy and takes but a couple of minutes max. Simply line up the shield under the hood so that the pins line up with the grooves in the underside of the hood as shown in the next photo.
Then simply press the pins lighly into the grooves. I started at the top of the Das Schild and worked my way down pressing each pin in a little to check for alignment and once I saw that everything was fine I pressed each pin in as far as it would go, compressing the foam on the backside in the process. Here is the Das Schild fully installed. It literally took a minute or two for the whole process.
I double checked all of the pins to make sure each one was firmly seated and checked for any gaps. As you can see from this next close-up photo there are none, the Das Schild fit perfectly!
Now my hood is protected from anything in the front trunk accidentally banging up into the hood and denting it from the inside out. Since the front hood is now aluminum the potential for damage is greater than the old steel hoods, and those could still be dented. The Das Schild will protect your hood and is a very easy modification. Here is a final picture of it installed showing the whole hood and trunk."
Old 06-25-2008, 03:14 PM
Jon996
Jon996's Avatar
I think I will order one for my 996 too. Almost slammed it shut on the roller handle of my carry on!
Old 06-25-2008, 11:14 PM
Botsy67
Botsy67's Avatar
I am also interrested in the GB price for a 996 lid-liner. Please keep us updated on the GB status... Cheers.
Old 06-25-2008, 11:17 PM
skiracer
skiracer's Avatar
I'm in.
Old 06-25-2008, 11:29 PM
redridge
redridge's Avatar
Im in!
While bleeding my brakes, the lid suddenly slammed on my power bleeder. Now I have a nice dimple that I have to press flat.
Old 06-26-2008, 12:31 AM
Lidliner
Basic Sponsor
Lidliner's Avatar
Default 997 Leads the pack with 993 hot on the trail after day one!
964 Forum
ilko
tbennett017
993 Forum
Smiles
Bearclaw
McQueen993
Raptor
air eater
quasr
rufstuf
Fred's 964
Rob 97 993c2
Reddy Kilowatt
993Maineiac
md11plt
dlee888
simpsoap
glenn '88 944S
Mark in Baltimore
David in LA
JPS
Arrwin
Kcreager1
Turbodan
996 Forum
Ubermensch
Ray S
Delbox
Rob in WA
Jon996
Botsy67
skiracer
redridge
schwank
mborkow
997 Forum
larrytrk
Curt P
linklaw
MLindgren
acao
Edgy01
andre5
jjv
2006997C4SCab
rol607
ELUSIVE
fusion85
adfsouth
purrybonker
brendorenn
crg1717
Frino
cello
Restless
phillig
dog_tired
Harvey in MD
hidalgo
rhubbell
Bills911997
Maison
Da Hapa
hjacobs2000
2006997C4SCab
lthatch
Van Larson
jcroxton
987 Forum
Jim in St.Louis
Mark FM
Old 06-26-2008, 08:36 AM
Electric Lizard
Pinecone Watchman
Electric Lizard's Avatar
Jim, I put the hood half bra on my 996 when at DEs. It hooks into the slots on the underside of the hood. I take it that these slots would no longer be accessible if a Das Schild is installed.
Old 06-26-2008, 11:22 AM
cs jeff
cs jeff's Avatar
Was going to ask the same question....
Old 06-26-2008, 02:17 PM
Lidliner
Basic Sponsor
Lidliner's Avatar
Chris,
There are a total of 10 push clip holes on the front deck lid. I just leave the center clips out of the holes in mine. The other eight clips will hold the liner just fine.
Quick Reply: GROUP BUY-SCHILD LID LINERS
