REMOVING DRL's
#31
Look at the relay tray. There is a relay that is twice as wide as the others pull it.
Then check to make sure with the relay removed all other lights work. Someone a long time ago claimed that after removing the relay some lights did not work. Think he said the license plate light or some light in the rear of the car.
#32
You can't pull the wrong relay. The relay is a double relay meaning it is twice as wide as the rest of the relays. You will need to pull it firmly. Don't worry - you can't break anything except your back getting under the dash. The relay tray is above the brake/clutch pedals.
#35
Ohay, is the relay tray above the fuse panel to the left of the pedals? If so which relay do I pull? There are two (from what I can see) relays that are twice as long (is this what is meant by twice as wide?) as the rest. A pic would be awesome. So would a beer!
#40
Okay pulled the RELAY. its the BIG ONE, Top left Corner, white sticker with a black arrow on it... Well it did the job, but more... Rear Licence Plate Light does not come on at all & High Beams only work when you Hold it Pulled.. If you Push, Xenons go out and High Beam Halogens Stay On... Also i dont know it this is related at alll, my Radio turned on by its self after it turned of automatically....
