REMOVING DRL's
Hmm, tempting. clean house and well fed, or sugar momma? Decissions, decissions.
Wish I had an answer for you. I need to do the complete opposite of this on a 03 with xenons, anyone know if it is as easy as connecting fuses 9 and 10?
BTW Zookie, thanks for the recomendation on the Pfaff PSE. My dads cas sounds very nice, love the crackle on cold start. Can't wait to compare it to the OEM PSE on my car tomorrow.
Cheers, David
Cheers, David
I really don't have an exact answer but I would think this is basic electrical stuff. So here it goes.
If you found the light sensor and unplugged it from the harness, that might work. If that does not work, then run a jumper wire to close the circuit. It has to be one way or the other.
Not sure, but here is a relay designation if you want to try pulling them. If you do use I will settle for a french women OOHHH LA LA... but needs to be clean and well fed.
http://www.theschillings.com/boxrelay.htm
