996 Forum 1999-2005
Car won't take gas
Old 03-04-2011, 09:25 PM
  #46
fpb111
fpb111's Avatar
What year, model is your car? What is the white ring just to the left out of the pic?
As long as you are that far clean out the drains on each side of the bulkhead.
C4 is a little different shaped tank.
Old 03-18-2011, 04:23 AM
  #47
///Mous3
///Mous3's Avatar
Oh f*@k! I am having the same issue. I can hear clicking when I push down on the flapper at the mouth of the filler... so it can't be the blown fuse; checked the fuse as well...
I need to try filling upside down fuel nozzle tomorrow... even a different station too
C Rock999, were you able to fix the problem? Mine is 2004 GT3... this problem is annoying.
Old 03-19-2011, 05:28 AM
  #48
Pac996
Pac996's Avatar
I think the first page mentions how the problem is fixable at the dealer and a known problem. I think even the dealer might fix it free if the fix hasn't been applied yet.
Old 03-20-2011, 10:18 AM
  #49
fpb111
fpb111's Avatar
C4 has the fuel pump access under the cover in front of the battery.
Old 03-27-2011, 12:48 AM
  #50
///Mous3
///Mous3's Avatar
I am yet to figure out how to get to Part ID 21 "valve" at the post #10... also need to know how the signal is being triggered...
Old 03-27-2011, 10:30 PM
  #51
///Mous3
///Mous3's Avatar
so far this trick allows her to get a little more fuel... but has to refuel slowly, i.e., can't squeeze the nozzle all the way...
Old 03-28-2011, 08:48 AM
  #52
AudiOn19s
AudiOn19s's Avatar
***double post sorry***
Old 03-28-2011, 08:51 AM
  #53
AudiOn19s
AudiOn19s's Avatar
Gents,
Sorry I never followed up on this post for closure. I ended up pulling out the fuel filler neck, inspecting all of the vacuum stuff up there and found no issues, also found you cannot access the flapper valve from the filler neck opening at least not to do any good that is. Put everything back together and still had the problem.
Post #13 in this thread has the exact procedure that needs to be performed to fix my issue. I pulled the fuel sending unit out of the top of the tank (under the battery in my C2), zip tied the two fuel lines to the sending unit to keep them higher in the tank and out of the way and sure enough that completely resolved my issue. I couldn't beleive that two zip ties and about 1.5 hours of my time was all that was really needed to remedy the situation.
It's tight in there doing the work, but not a difficlt task by any means.
Andy
Old 02-14-2012, 02:40 AM
  #54
svldvc
Cruisin'
svldvc's Avatar
where exactly is that "fuel valve door" located? @ the #1, #2, or #3 that I circled (see my attachment).
Maybe I should just remove the valve door...problem is annoying.
Old 02-14-2012, 12:05 PM
  #55
fpb111
fpb111's Avatar
Read the post #53 just above yours by AudiOn19s
*Refer to your diagram above.
There is a TSB (Fuel Tank Hose Modification 5/99 2015)...It addresses
1. Difficulty filling fuel tank.
2. Running out of fuel due to incorrect fuel gauge reading.
*The flapper valve is at the bottom of #1, the hoses on #4 (fuel pump) get in the way of the valve on #1.
Porsche put out a TSB about this problem. Part of the TSB detailing the fix is contained in POST 13 on page 1 of this thread. You have to remove the fuel pump/sender assy and wire tie the fuel lines to the sender body.
See post #13 on page 1 of this thread. It has pics and instructions that Porsche recommends for addressing this problem. If you don't feel comfortable enough in your ability to follow the instructions on opening up the top of the fuel tank in the TSB (Fuel Tank Hose Modification 5/99 2015) that is referenced in post 13 on page 1 of this thread then see post #12 and follow that suggestion for repair.
Old 02-14-2012, 10:27 PM
  #56
svldvc
Cruisin'
svldvc's Avatar
Thumbs up
Thanks Frank.
That's all I wanted to know.
U r a great help!
Old 02-15-2012, 12:04 AM
  #57
fpb111
fpb111's Avatar
SVLDC,
I think the flap end is shown in Fig 1 on post 13, black tube in from the upper left. If the fuel hoses get loose and wedge under it they can foul the flap at the end of the filler restricting it's movement.
Old 05-15-2012, 02:06 AM
  #58
///Mous3
///Mous3's Avatar
Any one with 996 GT3 have had this problem resolved? I was told the fuel tank and the front suspension must come off to access the vent valve. Looking at 8 hours of labor charge to replace the valve...
Old 03-27-2013, 03:09 PM
  #59
RDUBiker
RDUBiker's Avatar
Well dangit, this is happening to me now. Wife's car is already in the shop for a coolant leak and I just had knee surgery so was planning to wait to fix it. Now I guess I'll have to move it up so I can fix the 996 as well. Hopefully not too time consuming.
Old 03-27-2013, 03:20 PM
  #60
RDUBiker
RDUBiker's Avatar
Correction - fuse E6 was blown. I'll try refilling with gas soon and if it blows again, perhaps I have to re-think where to pick my radar detector power source from...
Quick Reply: Car won't take gas
