996 Forum 1999-2005
Dealer shining me on regarding engine mounts?
Old 02-03-2009, 11:35 PM
Army Guy
Army Guy's Avatar
Default Dealer shining me on regarding engine mounts?
The local dealer is telling me that the engine mounts on my 03 996 need to be replaced soon as they are wearing out (50k miles on the car). Based on a visual inspection, neither I, not a trusted mechanic, are seeing anything. What would the syptoms be of mounts approaching the end of their service life? Anyone else have this done?
Thanks!
Old 02-04-2009, 12:33 AM
fpb111
fpb111's Avatar
The mounts are fluid filled. They wearout/leak and sag. Do a search for "Engine Mount hemorrhage" in this, 996, forum. There are a couple of threads that will give you some good info.
Old 02-04-2009, 01:13 AM
jyoteen
jyoteen's Avatar
Odd....I have 80k miles and still have the original mounts. Is your shifting any different?
Old 02-04-2009, 02:40 AM
92tsiawd
92tsiawd's Avatar
what are the symptoms of wearing engine mounts can you feel when you are driving?
Old 02-04-2009, 03:43 AM
ArneeA
ArneeA's Avatar
Vibration in the cabin during idle and normally no vibration when driving.
Old 02-04-2009, 08:52 AM
Nicolaasdb
Nicolaasdb's Avatar
how much for engine mount replacement??
Old 02-04-2009, 10:03 AM
Ray S
Ironman 140.6
Ray S's Avatar
I had to replace a mount on my 986. The rubber was cracking on the mount.
Old 02-04-2009, 10:20 AM
ivangene
Parts Specialist
ivangene's Avatar
Call Suncoast for part price... but to do the job seems like a few minutes / side. I lowered the motor off the mounts last week. That took only a couple minutes as there is only 1 large nut / side. Then the mount is only 2 bolts /ea. I bet having never dont it before I could swap them out in under 1 beer....
The parts are not super cheap, but it's an easy job (I think) and they do need replacing on some cars. I have read quite a few that needed it.
Old 02-04-2009, 11:33 AM
AudiOn19s
AudiOn19s's Avatar
You can literally pull the mount out and inspect it yourself in about 5 minutes.
I had one that went bad and was causing an idle vibration inside the car that was annoying. When I pulled out the mounts the passenger side mount was clearly startint to collapse and the angel of the main stud for the mount was not correct and was much easier to move around than on the mount that was still good from my car. No really good way to put that I suppose. They don't have to be leaking to be bad.
You can get replacements pretty darn cheap if you look around some on the net.
Andy
Old 02-04-2009, 11:51 AM
Ubermensch
Ubermensch's Avatar
Please define "pretty darn cheap".
I've recently noticed a new vibration in the rear of the car (almost like the glass is vibrating) and suspect a worn mount.
Old 02-04-2009, 01:23 PM
Meister Fahrer
Meister Fahrer's Avatar
Thanks!
What is your dealer estimating for this job?
You should also check with a local indy shop, let us know if you need ideas in your area.
Old 02-04-2009, 02:29 PM
AudiOn19s
AudiOn19s's Avatar
~$150 for a pair of new mounts. (aftermarket)
and seriously...they couldn't be easier to replace. All you need is a jack and some common hand tools and both mounts can be done in 15-20 minutes.
Old 02-04-2009, 05:29 PM
BillJ
BillJ's Avatar
I just bought a pair from Partsgeek.com for under $100 delivered.
Old 02-04-2009, 05:42 PM
Dave!
Dave!'s Avatar
Anyone have links handy with a how-to on changing/inspecting the mounts?
Just something to do if I'm feeling bored, and I have a bit (very small) of vibration at idle.
Old 02-05-2009, 09:23 AM
AudiOn19s
AudiOn19s's Avatar
Place a jack under the rear jacking point of the car and only pump it up to apply slight pressure so the engine doesn't move while you have the mounts out. (don't lift the car up)
Unbolt the 3 bolts from the top of the mount in the engine compartment. You may have to take the stock air box out to get better access to them. I have a CAI and did not have to remove it. (13mm I belivee)
Under the car you'll see one large nut where the stud from the mount passes through the sub frame. Ubolt this nut (17mm or 19mm) and the mount should then lift out from the top.
Quick Reply: Dealer shining me on regarding engine mounts?
