996 Forum 1999-2005
Oil pressure sender unit replacement - DIY
Old 08-03-2011, 11:36 PM
  #46
Shark Attack
Shark Attack's Avatar
this was a huge help! thank you. Will be doing mine soon.
Old 10-25-2011, 01:02 PM
  #47
Topaz330ci
Topaz330ci's Avatar
Does anyone have the part number for the sender unit for a 2003 4S?
Old 10-25-2011, 01:10 PM
  #48
logray
logray's Avatar
Same part for all 996/7 cars.
Part number in post 15 & 37
996.606.203.02
About $45.
Old 10-25-2011, 02:06 PM
  #49
Topaz330ci
Topaz330ci's Avatar
996.606.203.02
About $45.
Just making sure as some people mentioned different looking connections.
I got quoted $52.87 plus shipping.
I'm not going t buy it yet as I want to clean up the connectors first.
Thanks!
Old 10-25-2011, 03:55 PM
  #50
logray
logray's Avatar
They are all standard quick connect wire terminals, but IIRC Porsche changed the connector "look" a little on the different wiring looms throughout the years. Still the same connector underneath.
Old 10-26-2011, 09:18 PM
  #51
htny
htny's Avatar
just had this happen, will try cleaning otherwise it's crow's foot time
Old 04-22-2012, 08:12 PM
  #52
StevoUK
StevoUK's Avatar
Thanks for the pointers on this thread, gauge has been reading 5 when cruising at 80mph and occasionally dropping to zero.
Cleaning the contact connections first!
Old 04-23-2012, 09:28 AM
  #53
StevoUK
StevoUK's Avatar
I just removed the connectors, sprayed the tabs with WD40 and replaced them, job done.
Started the engine and got 5 reading even at tick-over.
Switched off and back on and restarted the engine and the gauge was reading 4 - which gradually reduced as the engine temperature rose.
Looks like it may have fixed it!
I will know when it stops raining and I can do a full test drive.
Old 04-24-2012, 01:49 AM
  #54
Hurdigurdiman
Hurdigurdiman's Avatar
I finally got around to changing that sending unit. It was a piece of cake!! It took more time to drive the car on and off the lift than it took to change it.
Step 1: reach hand in and unplug wires
Step 2: raise car
step 3: drink beer
Step 4: with a 19mm crows foot wrench and a wobble extension, loosen sender
step 5: have another beer
Step 6: lower car
step 7: drinka 'hic' nother deer
Step 8: reach in and screw the sender
Step 9: drink beer and congratulate yourself for being half cut
Step 10: reach the sender in hand and screw it in the um um 'HIC' 'fart'
Step 11: avanover beer
Step 12 raise the car up a bit then return to sender
Step 13: tighten new sender with 19mm crows thing then wobble your extension
Step 14: Drop the car have anover beer
Step 15: connect wires somewhere
Step 16: drink more beer and congratulate yourself on a job well done an go to the pub and get absolutly pissed out of your skull. Goodnight evy bloody..
I.m not under the affluence of Incohol as some tinkle peep I am....Hic..
You don't have to be crazy to drive a 996 but it helps lol....
Old 05-08-2012, 02:22 PM
  #55
gman3280
gman3280's Avatar
http://www.autohausaz.com/search/pro...=W0133-1799387,
The part # 996-606-203-02 is $66.25 here with shipping.
Old 05-23-2012, 08:47 AM
  #56
StevoUK
StevoUK's Avatar
Cleaning the terminals was not a permanent fix for me so ordered the Sensor - 48 quid in the UK.
Old 05-24-2012, 09:12 AM
  #57
StevoUK
StevoUK's Avatar
Ordered yesterday just before 12:00 noon. (ebay Porsche-apart in the UK just search for the part number, 48 quid.)
Delivered this morning at 10:20
Fitted without problems in less than 10 minutes. Oil pressure readings are now what I expected them to be (pics later)
photos soon.
Note that the GT3RS version is fitted horizontally to the end of a metal tube with a bracket and it is much easier to fit a standard 0.75 inch spanner on it.
http://www.flickr.com/photos/83374345@N00/7261235864/http://www.flickr.com/photos/83374345@N00/7261235864/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237106/http://www.flickr.com/photos/83374345@N00/7261237106/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261236290/http://www.flickr.com/photos/83374345@N00/7261236290/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261237862/http://www.flickr.com/photos/83374345@N00/7261237862/ by http://www.flickr.com/people/83374345@N00/, on Flickr
http://www.flickr.com/photos/83374345@N00/7261238262/http://www.flickr.com/photos/83374345@N00/7261238262/ by http://www.flickr.com/people/83374345@N00/, on Flickr
At tick over
http://www.flickr.com/photos/83374345@N00/7261558004/http://www.flickr.com/photos/83374345@N00/7261558004/ by http://www.flickr.com/people/83374345@N00/, on Flickr
at 3000rpm
http://www.flickr.com/photos/83374345@N00/7261558794/http://www.flickr.com/photos/83374345@N00/7261558794/ by http://www.flickr.com/people/83374345@N00/, on Flickr
Old 06-26-2012, 01:44 PM
  #58
mårran
mårran's Avatar
I think i´ve got the same problem on my 996tt. Can anyone give me a hint if the sender positioned in the same place as on the GT3 or ?? Metzger-engined as they both are... I just might have some more stuff in my way.
Old 08-12-2012, 09:25 AM
  #59
Porsche31
Porsche31's Avatar
Hi all. This is my first post on the forum. Just got my first Porsche 911. A 2002 Targa. More to come later. Haven't taken a descent pic to post yet.
About a week after closing the deal I started getting the failure alert and needle drop. Ordered a Porsche factory sending unit on eBay for $45 shipped and did the job yesterday with a buddy. I used the crows foot on a swivel attached to a one foot extension. I loosened it from the bottom of the car. I did not need to jack the car / remove tire. It was on very tight but I was able to pry it loose without using a hammer.
After the install we cranked her up and monitored around the base of the unit to ensure there was no seepage then drove it about 10 miles. Still no seepage. Everything seemed to be working fine but then I noticed the failure alert again last night when I sat in the car and turned the key to the second click so I could roll up the windows. I cranked the car and it went away and the needle was responding as it should. Then I shut off removed key, put it back in and turned to second click to recreate the scenario and I got the alert again. Im not too concerned about it but I will continue to monitor today and post my findings. I just wanted this to be documented in case anyone else has run into this or does so in the future.
This is a great DIY post and I look forward to working on / getting to know my car in the future with oil changes etc.
Old 08-12-2012, 09:59 AM
  #60
Van
Van's Avatar
Welcome to the world of Porsches! I would try to figure out if there's some break or crack in the wires that connect to the sensor - perhaps that's giving the computer/dash a fluctuating reading. Otherwise, there might actually be something wrong that is really restricting your oil flow.
Quick Reply: Oil pressure sender unit replacement - DIY
