Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Old 07-24-2009, 07:04 PM   #16
Tippy
Tippy's Avatar
Quote:
Originally Posted by LVDell View Post
pb blast?
Its like WD-40.
Cory
- 1987 Carrera 3.2 w/single turbo (T60-1/0.85 A/R) Guards Red/Black 427 rear wheel hp/2750 lbs. - granny shifting and steet tire 1/4 mile = 124 MPH @ 12.4 @ 80 degrees, high humidity
R.I.P. - I delivered the "Money Shift" - valve float @ 9100 RPM doesn't play well with the exhaust valves/pistons relationship. Expected revival - early 2010
- 2000 996 Aero- Basalt/Beige - Gone @ 102,000 miles
Tippy is offline   Reply With Quote
Old 07-24-2009, 07:06 PM   #17
Tippy
Tippy's Avatar
It seems every damn clip in these cars is a new rubics cube every time
Suggestions on proper unclip procedure?
Dell, arent you a Dr.? You can figure it out, I assure you.
Cory
Old 07-24-2009, 07:09 PM   #18
LVDell
LVDell's Avatar
Touche'
Problem is that it is finals week and I just wrapped up. My brain is mush trying to get grades done and listen to all the grade adjustment requests. Thanks God tonight is martini night!
LVDell is offline   Reply With Quote
Old 07-24-2009, 08:24 PM   #19
gota911
Newbies Hospitality Director
gota911's Avatar
Location: Currently in Dallas, TX going to... ?r?e??i??e, ??
Quote:
BAWHAHAHAHAHA!!!!
Tim K.
Still Lurking About!
I used to own a 996. Really...... I DID!!
SIG by Programmatore
gota911 is offline   Reply With Quote
Old 07-24-2009, 08:35 PM   #20
LVDell
LVDell's Avatar
Oh sure, pick on the guy who's brain is in the toilet right now. Real fair
Old 07-24-2009, 09:06 PM   #21
springgeyser
pb blast?
PB Blaster is one of the best penetrants I used to loosen stubborn nuts. It is much better than WD-40. I spray it liberally days before I actually work on the car.
Autozone or Kragen, if they have one in your area, will loan out a O2 socket for FREE.
springgeyser is offline   Reply With Quote
Old 07-24-2009, 09:08 PM   #22
LVDell
LVDell's Avatar
Thanks for the heads up. I'm heading to Autozone in the morning and I'll look for PB Blaster as well.
Old 07-25-2009, 01:07 AM   #23
67FJ45
67FJ45's Avatar
Good point. I'll disconnect the wiring harness and then remove them once off the car.
BTW, what in the world is the O2 removal tool? Dealer thing?
Dell,
If you unclip the O2 sensors and remove the cats, then twist off the sensors, you don't need a slitted socket. An open end wrench should work well.
The electrical fasteners are definitely difficult to remove. I don't know about 986 sensors, but 996 sensors are fastened as follows. The side of the fastener connected to the O2 sensor has two small locking tabs that must be depressed before the fastener can be pulled apart. If your fingers are husky, it could be difficult without using some kind of tool to depress the tabs. I've attached pics here, complete with a Dell background.
Good luck!
____________
40 Jahre #418
67FJ45 is offline   Reply With Quote
Old 07-25-2009, 08:24 AM   #24
LVDell
LVDell's Avatar
Thanks! Just what I was looking for. Maybe I'll try to unclip these suckers first.
Nice play on the "Dell" background!
Old 07-25-2009, 12:14 PM   #25
67FJ45
67FJ45's Avatar
One more bit of info, Dell. There's a sliding retainer that covers the clips. It looks like this on the 996 (see pics). You can pull the entire electrical connector assembly out of the clip that mounts it to the car body (1st 3 pics). Then you just pull the red sliding retainer up, and the connector will come apart easily (4th pic).
I hope my earlier post wasn't too confusing.
____________
40 Jahre #418
Old 07-25-2009, 12:38 PM   #26
LVDell
LVDell's Avatar
Got it! Had another friend over and was able to describe exactly what you just did. Thanks so much for the help!
Old 07-25-2009, 04:52 PM   #27
himself
himself's Avatar
Forgot I had this link. For others in the future I suppose...
http://mike.focke.googlepages.com/oxygensensors
-td
himself is offline   Reply With Quote
Old 07-25-2009, 04:52 PM   #28
LVDell
LVDell's Avatar
-td
Beers on you next time!
Old 07-25-2009, 07:15 PM   #29
67FJ45
67FJ45's Avatar
-td
Wow, that's a nice resource. Good link!
By the way, Dell, what are you doing to the exhaust system?
____________
40 Jahre #418
Old 07-25-2009, 07:18 PM   #30
LVDell
LVDell's Avatar
Haven't figured out yet. Have it narrowed to a few different setups. Should have a decision next week sometime.
Tags
996, autozone, break, freight, harbor, o2, ox, oxygen, pb, porsche, rdu, removal, sensor, stuck, sucks, tool, wrench
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
