classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#16 |
Rennlist Member Join Date: Aug 2006
I was told what really hurts the engine when it's cold is "load". Revving the car to 5-6k when cold, stationary, and in neutral - should not really be harmful. In fact u see racing mechanics run out to paddocked cars - start them, run them through the rev range, and shut them off.
When I had a S2000 if I blipped the throttle after starting it - I'd swear it would warm quicker once I drove away. But as said above - I would never put a high load on a cold engine - so I never drive over 3k unless car is up to temp.
#17 |
Sure, the engine hasnt had enough cold runs to make a good wear pattern yet. I bet if it were 5k miles, the motor would still be around IMO.
Cory - 1987 Carrera 3.2 w/single turbo (T60-1/0.85 A/R) Guards Red/Black 427 rear wheel hp/2750 lbs. - granny shifting and steet tire 1/4 mile = 124 MPH @ 12.4 @ 80 degrees, high humidity R.I.P. - I delivered the "Money Shift" - valve float @ 9100 RPM doesn't play well with the exhaust valves/pistons relationship. Expected revival - early 2010- 2000 996 Aero- Basalt/Beige - Gone @ 102,000 miles |
#18 | |
Quote:
Second, why do they do that? What's the reasoning? Just curious.
#19 |
Rennlist Member Join Date: Mar 2009
Thermal shock is a fact in northern climates. Back in the day when I had to travel WAY north of where I live - as in 12 hours north - you would wake up to an air temp of -40F and even with the car plugged in to an AC outlet (without it - wait until spring!) you could hear all sorts of weird sounds for the first few minutes as the coolant in the top of the motor (heater OFF to warm up quicker!) met different areas of the motor that were warming up faster I guess. I'd sit there, the seats made out of ice cold cement (no heated seats!) scraping off the inside of the window wondering how much lubrication I had with semi solid oil trying to flow from the back of the pan and into the oil pick up. I didn't even want to think about what would happen if I rev'ed up the motor! (Another reason other then salt to hibernate my toy until April!)
Now this IS extreme but the idea of allowing your motor's internal parts to all reach a uniform temp before high RPM's is valid. We also have issues of very cold gas from the tank and running through injectors into hot cly's to worry about up here in sub zero weather as I have heard of people breaking rings in the first minute after starting the car in these conditions. I bet 0w 0 would sell quite well up around Cochrane Ontario in the winter months!
1999 996 C2 'Tip' (Summer Toy) 2003 Toyota Echo (Winter non-Toy) 1993 Mazda MX3 (Now in Mazda Hell )2009 Mazda 5 (New Porsche support vehicle!) 2005 Cadillac CTS 3.6L (No soup for GM - gave it back! )2005 Suzuki SV650S (Wife and Daughter's toy - Don't ask!) |
#20 |
User
My understanding has always been that the mechanical argument for warming it up by driving it was that it avoided uneven heating and hot spots.
But I also know that this practice was originally encouraged for emissions reasons. Idling is obviously not very green, and the cats don't work until they're hot. A lot of stuff like oil change intervals, viscosities, startup procedures, timing and mixture settings, etc. have nothing to do with performance or reliability. It's all about emissions compliance. |
#21 | ||
Quote:
Quote:
So, does the friction from (friction bearing, metal to metal contact) loads really warm up the engine that much quicker or is it the heat dispersed from combustion that ultimately is responsible for engine temps? If it is the former, then I could see uneven heating. We never got that into depth in school for aviation reciprocating engine theory (same as a car engine).
#22 |
Rennlist Member Join Date: Aug 2009
Good thread.
I remember seeing a graph in an HP Engine Series book on the Ford FE that showed Engine Wear Vs Water Temp. Very interesting! I know we're all in agreement that "cold running" and "engine wear" go hand in hand, but here is a graph of similar data to what I saw way back when. I love the internet. ![]() So the hotter the engine the better it is on wear, from a metallurgical stand point. But excessive heat can and will adversely affect other aspects. Food for thought. And, being an engineer, I love data.
'01 996 C4, Ylw/Blk 6sp Areo '67 Mustang Fastback, 390FE S-code 4sp (now with TCI C6) Video '70 Mustang Mach1, 351C 4V M-code 4sp (now w/ worked 2V's & T5) '95 Toyota T-100 Pickup, V6, mild lift '05 Suzuki SV650S, (transformed into a ring on my fiance's finger) '03 Honda CRV '89 Nissan Stanza (yellow bumper as paint came off!! Awesome) '84 Toyota SR5 Pickup '78 Chevy Stepside 4x4 w/ 1ton trans/T-case/axles '75 IH Scout, Orange |
#23 |
Funny you mention that. Driving around in our sort of tundra like weather I recall a car I was driving up north was suffering from what aviation people would say was 'carb icing'! Nothing you could do about the problem other then drive it in a lower gear and rev the **** out of it to produce as much heat as you could. Just like a Cessna at 10K and dropping alt from icing - my car was chugging along slower and slower as the intake iced up. I ended up stuffing newspaper in between the rad and the grill, blocking part of the ram air intake and driving without the heater on for over 200KM! Fuel injection was a god send in our part of the world.
#24 |
New User
I just swapped from a supercharged genuine 500HP mustang to a 2004 996 and IMHO warming up should be done on the move, BUT redlining, in the Mustang anyway was a recipe for throwing a rod, it will always be the weakest component that goes first! Here in Texas it never gets that cold anyway and the motor warms up in a mile or two, until then I keep below 4000rpm
#25 |
Rennlist Member Join Date: Mar 2002
In my case I try to keep the revs down and won't go to redline but to keep it below 5k rpm is tough for me...Reason being that where I live there is a divided four-lane road that I must take a left on. So in order to make it out of my neighborhood I need to give it a little throttle in order to get the car going at the same speed as traffic.
It's far from redline but also a bit above the 3k-4k limit some say to keep it under. Granted these aren't sub-zero temperatures I'm starting off from and I do have 0w-40 in the car but I do see the oil pressure gauge is pegged at 5 bars during this maneuver. Hopefully it won't make too much of a difference but my only option is to let it sit there for twenty minutes while it warms up fully.
![]() 2002 Porsche C2 Cabrio 91 Porsche 944 S2 Cabrio - Sold on 4/27/09 after 7 years ownership! See my photo album! |
#26 | |
User
Quote:
![]() As I said, this is the story I've always got about this. I think it's even come up on threads here or on Renntech. Either way, I'm bringing a knife to this gunfight. |
#27 |
Rennlist Member |
4-corner piston scuffing is a risk if you over-load at low operating temperatures. Piston will grip the liner at four "corners", leave some marks, then high oil consumption if you're lucky, a seized piston if you're not. The piston doesn't take the right shape until it's up to temperature.
Starting the car "cold" and opening it up for a quarter mile is not the best idea. That being said, I don't think there is any issue with starting the car and headed for the grocery store right away... My 2 cents...
Granger968 2001 996 Carrera 2003 BMW R1150GS Adventure 2008 KTM 530 EXC-R (finally gone!!) 2003 Nissan 350Z Track (gone) 1998 Kawasaki KLR650 (gone) |
#28 | |
Quote:
I know air-cooled aviation motors have a tight fit in the liner towards the top and then looser fit towards the bottom when cold. Once at operating temp, the liner is supposed to be as linear and straight as possible for the piston to travel in. This is due to the most amount of heat residing in the top of the bore.
#29 |
Rennlist Member Join Date: Oct 2006
The truth is... its the amount of time that the car reaches to temp. When you redline an engine when cold... The delta temp of various parts of the engine will be at its greatest... There will be cold spots and hot spots.... gradually bringing the car up to temps reduces stress on an engine. This is one of the reason why the 2 radiator line intersects each other so that the delta temps between the 2 rads would be a wash...
Oh, did I mention I stayed at the Holiday Inn last night...
#30 |
Rennlist Member Join Date: Mar 2003
My suggestion is not to redline any engine until the oil reaches operating temperatures. Oil pumps put out flow and that's related to viscosity. The colder the oil, the thicker the oil and the less the flow for a given pressure. Porsches in particular have tight tolerances between moving parts and require sufficient oil for lubrication. It's not to say you'll have a catastrophic failure; it just is not optimum lubrication as the engineers designed when the engine is cold.
On my M5, the engineers provided lights inside the tach that show maximum recommended RPM until the oil reaches operating temperature. They start off with a max recommended rpm of 4k when cold then they gradually go off as the sensor in the oil pan detects the oil has reached operating temperature. Eventually, they all go out except the last one at 7k rpm. This photo shows some of the lights off because the oil is warm. When totally cold, they are all on initially.
Tobacco Metallic 1979 911SC Targa Guards Red 993 C4S Titanium Silver 2003 M5 |
| Tags |
| 95, cold, engine, hard, high, lining, mazda, motor, mx3, oil, red, redlining, revving, saab, start |
| Thread Tools | |
