Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Old 10-12-2009, 11:22 PM   #61
jasper
jasper's Avatar
Here's one that hasn't come up yet.
The oil filler pipe can be unclipped from the airbox. There's a bellows section in the pipe which then let's you tilt the pipe up a good 6 inches to make adding oil a no-mess breeze.
Used this today when I did my oil change.
jasper
2002 - 996 - Silver - soon to be liteweight special
2002 - 996 - Seal Grey - No PSM! - gone too
1978 - 911 lightweight - pistons, carbs, suspension, brakes - gone now, but it was noisy and fast
jasper is offline   Reply With Quote
Old 10-12-2009, 11:32 PM   #62
knfeparty
knfeparty's Avatar
The little led that is in the middle of the dash right under the windshield lights up red in conjuction with the led on the key remote to let you know it is working.
PCM 2 has a lot of out-there features such as a setting for calibrating the trip computer for each time you get new tires.
It also can detect CD names / track names for most CDs, even if they are a mix cd made by the user. For CDs that don't have readable track data, you can enter the name of the cd in PCM 2 so that it will show up in the CD list for the CD changer.
E Stock Alpine White on Blue 1989 944 NA 2.7L 8v.
Options: 030 (Sport Chassis) 220 (LSD), short 5th, driver sport seat cloth
GT Silver 2004 911 40 Jahre edition
PCM2, heated memory comfort seats, 030, 220, x51 included of course
knfeparty is offline   Reply With Quote
Old 10-12-2009, 11:38 PM   #63
redridge
redridge's Avatar
there is a coin holder in the rear center compartment.... yeah, a coin holder.
redridge is offline   Reply With Quote
Old 10-12-2009, 11:54 PM   #64
AndyK
AndyK's Avatar
Quote:
Funny, I JUST found this out when reading a parts diagram on the center console! Those little fins are coin holders!? Go figure!
2000 996 C2 - Arctic w/ Black full leather, 21k miles
'89 944 S2 - SOLD
'88 944 Special Edition - SOLD
PCA NNJ
AndyK is offline   Reply With Quote
Old 10-13-2009, 06:24 AM   #65
RaphaelPlascencia
User
RaphaelPlascencia's Avatar
Question
Quote:
Originally Posted by ivangene View Post
(1) If you fill the tank with the engine running the gas guage will not show full until you drive about 10 miles (or shut the car off, remove the key and turn it back on)
Why the hell would you fill the tank with the engine running?? Am I the only one who finds this odd?!
Lol.
RaphaelPlascencia is offline   Reply With Quote
Old 10-13-2009, 09:00 AM   #66
frankfast
User
Is there anything that has to be reset after removing a dead battery from the car?
frankfast is offline   Reply With Quote
Old 10-13-2009, 09:44 AM   #67
redridge
redridge's Avatar
Quote:
need to input the radio/nav code... thats it. The ecu will adapt to your driving habits...
Old 10-13-2009, 01:50 PM   #68
PasPar2
PasPar2's Avatar
what I learned looking for tranny oil for my 2002 996 tip:
The tip-S is is made by Mercedes Benz and is also used in many MB cars, as well as some Dodges and Chryslers. The transmission is called "722.6". It is considered "bullet proof" mechanically and mostly suffers from electronic issues rather then mechanical. Some 722.6's have a bolt on the torque converter to allow draining the oil - the 996 version doesnt not. This tranny installed in most MB models has a filler tube in the engine compartment but the dip stick needs to be purchased separately. The 996 version doesnt have a filler tube and gets filled via a fill bolt on the transmission.
the correct fluid for this tranny is the fuchs 3353 labels "Titan" available from Pelican parts. The gasket and filter look identical to the MB spec ones but cost 3x and 7x more respectively for the Porsche.
PasPar2 is offline   Reply With Quote
Old 10-13-2009, 02:55 PM   #69
Tippy
Tippy's Avatar
Although not confirmed myself, I have read that the Tip cars have a direct pulley on the alternator while the manuals have a sprag type pulley.
I remember my Tip alt pulley was solid.
Can anyone confirm this?
Cory - "Professional Shade-Tree Mechanic"
- 1987 Carrera 3.2 w/single turbo Guards Red/Black 427 rear wheel hp - granny shifting and steet tire 1/4 mile = 124 MPH @ 12.4
R.I.P. - I delivered the "Money Shift" - valve float @ 9100 RPM doesn't play well with the exhaust valves/pistons relationship. Expected revival - early 2010
<-------- Yes, the background was photoshopped of my car....as you can tell
- 2000 996 Aero- Basalt/Beige - Gone at 102,000 miles
Tippy is offline   Reply With Quote
Old 10-13-2009, 03:27 PM   #70
wross996tt
wross996tt's Avatar
depends on the year of your car...MY 03+ radio code is stored in the DME.
Statman
04 996TT Cab (pics)
Go Buffs!
Fight On!
wross996tt is offline   Reply With Quote
Old 10-13-2009, 03:35 PM   #71
wwest
User
wwest's Avatar
"..The ecu will adapt to your driving habits.."
And here I thought Porsche owners were too bright to believe that CRAP..!!
Maybe in the general case.
Even if the ECU does "learn", adapt, to some aspects of your driving habits those will be, MUST, be erased upon each engine stop/start cycle.
wwest is offline   Reply With Quote
Old 10-13-2009, 03:48 PM   #72
Jim Griffin
User
Yes the 996 Tiptronic S transmission is a MBZ tranny. As for the AWD cars, C4, C4S, Turbo, only the 996 Turbo Tiptronic uses another MBZ tranny (F-1) with different OEM part number and they are not interchangeable due to bolt pattern. If you build an aspirated 996 with more horsepower (ie supercharger) you may risk damage to the Tiptronic Transmission, if you were thinking "the Tiptronic, if it can withstand the bHP from a turbo, then it is okay for a supercharger" idea. Not.
Jim Griffin is offline   Reply With Quote
Old 10-13-2009, 03:59 PM   #73
redridge
redridge's Avatar
huh? So, when you put an exhaust or a cai... the ecu wont know the diff between aftermarket or stock? The engine management on these cars are adaptive... just about any modern sports cars have this feature. When you unplug the battery, the mapping goes to default... as you drive... the car learns your driving habits. In other words... it re-maps itself based on trending patterns of the way you drive.
Old 10-13-2009, 04:31 PM   #74
peavynation
peavynation's Avatar
Yep, Tippy, confirmed. Tip's pulleys are hard connected to the alt shaft, whereas the manuals have a free-wheeling clutch (sprag) type pulley, sort of like the rear cassette of a bicycle. Alt can then freewheel back down to engine speed rather than be sucked down with it.
I'm guessing this is this to decrease drag on the motor, and help keep revs up when shifting???
'01 C4 Coup, Ylw/Blk 6sp Areo
'67 Mustang Fastback, 390FE S-code 4sp (now with TCI C6) Video
'70 Mustang Mach1, 351C 4V M-code 4sp (now w/ worked 2V's & T5)
'95 Toyota T-100 Pickup, V6, mild lift
'05 Suzuki SV650S, Yosh exhaust (just sold; sniff sniff)
'03 Honda CRV
'89 Nissan Stanza (yellow bumper as paint came off!! Awesome)
'84 Toyota SR5 Pickup
'78 Chevy Stepside 4x4 w/ 1ton trans/T-case/axles
'75 IH Scout, Orange
peavynation is offline   Reply With Quote
Old 10-14-2009, 12:56 AM   #75
wwest
User
wwest's Avatar
Not immediately, not unless you "tell" it.
The engine management on these cars are adaptive... just about any modern sports cars have this feature. When you unplug the battery, ("telling" it") the mapping goes to default... as you drive... the car learns your driving habits.
No, it learns new engine/sensor/control mapping parameters while you drive, based on how you drive, NOT YOUR driving habits.
Once a parameter is "mapped" it will not be re-learned in accordance with ANYONE's driving habits. Excluding driver unique parameters that are ERASED upon each stop/start cycle, MUST be erased.
My statement applies to the systems "learning" "...your driving habits..."
Modify the engine in some manner and the ECU will eventually learn new parameters if/as needed. Or you can disconnect the battery for a period and the ECU will adapt to the "new" parameters more quickly.
Tags
34, 36, 996, activate, aero, battery, bulb, button, disconnect, kit, led, position, saab, switch, top, yellow
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
