Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Old 11-03-2009, 09:09 PM   #31
peavynation
peavynation's Avatar
Are those Tarett pieces? They look like it.
'01 996 C4, Ylw/Blk 6sp Areo
'67 Mustang Fastback, 390FE S-code 4sp (now with TCI C6) Video
'70 Mustang Mach1, 351C 4V M-code 4sp (now w/ worked 2V's & T5)
'95 Toyota T-100 Pickup, V6, mild lift
'05 Suzuki SV650S, (transformed into a ring on my fiance's finger)
'03 Honda CRV
'89 Nissan Stanza (yellow bumper as paint came off!! Awesome)
'84 Toyota SR5 Pickup
'78 Chevy Stepside 4x4 w/ 1ton trans/T-case/axles
'75 IH Scout, Orange
peavynation is online now   Reply With Quote
Old 11-03-2009, 10:56 PM   #32
jrgordonsenior
jrgordonsenior's Avatar
Quote:
Yes on PSS9's....
JR Gordon
99' 996 Spec
05' 997 S-garage queen
02' Boxster S
06' F350 CC, DRW, PSD
06' 28ft. Pace Aerosport tag
06' Featherlite 3110
jrgordonsenior is offline   Reply With Quote
Old 11-04-2009, 12:11 AM   #33
himself
himself's Avatar
Default Images
Here are the images from the OP.
-td
6GT3
E350
C55 AMG
335i [gone]
00 996
himself is offline   Reply With Quote
Old 11-04-2009, 12:18 AM   #34
X51
X51's Avatar
I sent td (user name "himself") a couple pics to post of my fabricated drop links and bar set up. I couldn't get the pics to upload. My wife calls my computer a dinosaur.
I like the shock collar - approx how much do those cost? Isolating the link from the steering rack makes a tremendous amount of sense. Turning my steering wheel to get pics showed me how much stress the link is experiencing under my current setup. Will drop the links and bar apart on Thursday and report back. Any other comments after pics are posted are appreciated.
X51 is offline   Reply With Quote
Old 11-04-2009, 12:23 AM   #35
peavynation
Quote:
Tarett's stuff is really top notch. I can't remember how much his collar and link setup is, but give him a ring. His name is Ira, he's a real good guy. Tell him Joel Peavy sent you. www.tarett.com His shop is just across the street from where I work; very convenient.
'03 Honda CRV
Old 11-04-2009, 07:51 AM   #36
RamVA
User
I'm not sure if this is the problem, but I *think* the the droplinks are swapped left-to-right. The upper bolts should pass through the lower shock collar going back to front (i.e. the nut on the forward side), and these are run backward. That's a clever way to make it work (if that's what was done). It may be causing some binding when the wheel travels, though, which would kill the ride. Like I said, I'm not sure it's the problem, but I think you are going to need adjustable links (there are lots of options).
I'm curious what your guy did to modify the links. They look different from mine (which are longer and slimmer), but my car is a Mk1/3.4.
RamVA is offline   Reply With Quote
Old 11-05-2009, 01:05 PM   #37
X51
X51's Avatar
Thanks to everyone for their insights and recommendations. Was able to get time today to look at it with the indy. Springs, shocks, bars, drop links - all were in proper order and installed as they should be. We moved the front bar to full soft and that made a significant difference.
Now I just need to get new front mounts to get rid of the popping / creaking noise that the stock mounts create with the Bilsteins. Thanks again for the help in troubleshooting. This is a great forum.
Old 11-05-2009, 02:11 PM   #38
SH || NC
SH || NC's Avatar
This has also been discussed. A couple OEM parts are reused during the install and its important they are installed correctly; a couple of rubber seals and thrust bearings IIRC. No creaking or popping after my PSS10 install last year.
Here is an excerpt from a post here:
Quote:
I have had this issue for 6 months since the PSS9's were installed..... After several trips back to the indy shop that did the install and being told that this was normal, I took the car somwhere else to have it looked at (noise getting louder).
Come to find out that there are parts that need to be harvested from the stock mounts (Rotators) and installed with the PSS9 kit. Of course the PSS9 installation instructions don't refer to this... and guess what, mine are missing.
http://www.pelicanparts.com/PartsLoo...-00-Frame3.htm
You need the item number 11 - Angular Contact Bearing
part number 996 343 501 00
This is the thrust washer. It is an assembly of metal parts that allows the top half to rotate independent of the bottom half. This is what allows the entire strut assembly to rotate independent of the body. If you don't have this, the coils can be twisted, bind up, and then release causing the boing sound when turning at low speeds.
2004 SY GT3
SH || NC is offline   Reply With Quote
Old 11-05-2009, 07:30 PM   #39
RamVA
User
I would take it somewhere else.
Old 11-05-2009, 08:24 PM   #40
himself
himself's Avatar
Quote:
There are some gurus of setup down Houston way. I know that Porsche and Indy shops are competent for most things, but when it goes bad, you really need a "somebody."
I second the thought to get another opinion.
-td
6GT3
E350
C55 AMG
335i [gone]
00 996
Old 11-05-2009, 11:06 PM   #41
jrgordonsenior
+3 on taking it to another shop. Also, do get the adjustable drop links....
JR Gordon
99' 996 Spec
02' Boxster S
Old 11-05-2009, 11:19 PM   #42
X51
X51's Avatar
Thanks, guys. Will follow up on all of the above.
Tags
99634350100, bilstein, clunk, collar, drop, links, metal, noise, noisy, pss10, pss10s, pss9, tarett
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
