Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Old 11-05-2009, 04:08 PM   #1
georgiadis
User
georgiadis's Avatar
Default Clutch replacement - Labor
Hello all!
I am heading towards a clutch replacement, so I have a few questions.
I have read that the service manual specifies that it should take 3 hours 50 minutes, but I couldn't find that either in the general or in the manual transmission manual.
Can someone help with that?
Could someone briefly describe what needs to be removed / dropped to replace the clutch?
I also have a leak from my valve covers that I would like to fix and I was told that the engine has to be dropped.
Are the 2 jobs the same labor-wise (i.e. should I be paying double labor) ?
Finally, can anyone recommend a good and reasonably-priced shop in the West LA area (or around)? My first quote from a dealership was $2,500 for parts and labor and that is absurd!
Thanks!
Note I am taking about an '02 996 RWD.
georgiadis is offline   Reply With Quote
Old 11-05-2009, 04:21 PM   #2
soverystout
soverystout's Avatar
Quote:
Originally Posted by georgiadis View Post
Hello all!
Thanks!
My service advisor (P-car dealer) said one of his techs can have the trans out in an hour.
The trans has to come out for the clutch replacement, not the motor.
The dealer quoted me about $800 just for the clutch kit. It can be had from Sunset Porsche (by calling them and having it delivered to you) for about $500 which includes shipping to most places.
If you brought the clutch kit to an indie you might pay $500 for labor. THis does not include a flywheel. That's another $850 item.
Can't comment on the valve covers. make sure you are not overfilling the oil (if you change your oil or top it off on occasion) as that will contribute to oil being dumped out of crankcase valve that may look like a valve cover gasket leak.
Don't rely on the computer oil level system in the dash, it lies!!!!!
03 996 6spd Cpe satin silver/metropol blue w PSE,Sport Design wheels, Alum/lthr shifter and parking brk,power comfort seats with heat,lumbar and supple leather,Bose,colored crests,Bi-xenons and PSM
DD - 06 Mazdaspeed6 GT Titanium Grey/Black
soverystout is offline   Reply With Quote
Old 11-05-2009, 06:57 PM   #3
function12
User
function12's Avatar
Also make sure it is not a spark plug tube leaking. Much easier fix if it is.
function12 is offline   Reply With Quote
Old 11-05-2009, 07:21 PM   #4
georgiadis
User
georgiadis's Avatar
Thank you both!
If the motor comes out, isn't the transmission accessible in order to replace the clutch?
Old 11-06-2009, 11:41 AM   #5
soverystout
There is not much point to taking out the motor and not the trans.
To do the clutch, the trans comes out. To replace the valve cover gaskets, both the motor and trans would come out together. Then you would split the two, replace the clutch, join them back together, and put them back in as one.
Old 11-06-2009, 12:44 PM   #6
msark
Although not in West Los Angeles I have used TRE Motorsports in Van Nuys and found them to be very helpful and cost effective. David is the owner and the phone number is 818 909 9220. They have done work on my 1991 Targa that I just put up for sale (a bargain!) and the PPI just 2 weeks ago on a 2001 Cab that I just bought.
msark is offline   Reply With Quote
Old 11-06-2009, 05:11 PM   #7
georgiadis
User
georgiadis's Avatar
Thanks a lot to both of you!!! That's the info I wanted!
Old 11-06-2009, 09:40 PM   #8
rwiii
User
rwiii's Avatar
Shouldnt you replace the RMS at the same time?
rwiii is offline   Reply With Quote
Old 11-06-2009, 10:04 PM   #9
MarkD
MarkD's Avatar
Quote:
If it is leaking/seeping, yes. There are a couple of Service Bulletins that should be considered when doing the clutch.
The shop doing the work should advise.
_______________
Mark
97 993 turbo Black/Black - 2WD, Kinesis K28s, PSS9s, 2WD trans mount, FDM SSK, etc.
993 Turbo Exhaust Video: http://www.youtube.com/watch?v=dQzfJm9eGLw
96 993 Cab Blue Turq/Grey - M033/Bilsteins, Fister Stage II Exhaust
06 Cayenne S - Family Truckster
'57 Speedster replica by Vintage Speedsters - Yellow, 2.0l Engine by Lyle Cherry
'07 Mini Cooper S
MarkD is offline   Reply With Quote
Old 11-07-2009, 01:38 PM   #10
Ahmet
Ahmet's Avatar
Send a message via AIM to Ahmet
If you were close to me, I'd do the job for you at about $500 for labor. It's a very simple procedure as far as clutches go. Valve 'cover' is not bad either, I do it with the engine in the car...
Misc./Turbos ETC.
Ahmet is offline   Reply With Quote
Old 11-08-2009, 10:46 PM   #11
georgiadis
User
georgiadis's Avatar
Thanks a lot guys! I got a quote for $1250 and I will probably have it done there.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
