classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
New User
VFE / Vortech Supercharger Stage II:
Parts: 0.2” smaller pulley (From 3.8” to 3.6”) Vortech part number 2A036-361 - $78.95 link - www.vortechsuperchargers.com/product.php?p=42 20mm smaller 6-rib Gatorback belt (Original part number 6PK2655) 20mm smaller belt part number 6PK2635 (can be purchased at AutoZone) link - www.goodyearep.com/productsdetail.aspx?id=3128 Notes: System must be retuned for optimal air/fuel mixture following modifications. Boost, Intake Temperature and Water Temperature gauges should be added. Water pump power should be rewired to ignition, not accessory (phone). Water pump LED should be mounted near water temperature gauge. Expected change: Dynamometer horsepower from base (445.9) to base + 33.1 (479) Dynamometer torque from base (327.3) to base + 18.9 (346.2) |
#2 |
Rennlist Member Join Date: Aug 2006
I would have a hard time boosting a 11.3:1 motor anymore than what the original kit used.
But, as long as you don't run lean, run too hot inlet temps, or detonate, it should stay together. There just isn't much margin for anything getting out of whack IMO.
Cory - Just a trollin' ![]() - 1987 Carrera 3.2 w/single turbo (T60-1/0.85 A/R) Guards Red/Black 427 rear wheel hp/2750 lbs. - granny shifting and steet tire 1/4 mile = 124 MPH @ 12.4 @ 80 degrees, high humidity R.I.P. - I delivered the "Money Shift" - valve float @ 9100 RPM doesn't play well with the exhaust valves/pistons relationship. Expected revival - early 2010- 2000 996 Aero- Basalt/Beige - Gone @ 102,000 miles |
#3 |
Super User
How much boost AFTER the throttlebody are you getting with the 3.8" pulley? What year car is it?. Your expected change is far too high if you are tallking whp.
#4 |
Rennlist Member Join Date: Sep 2008
Have uprated other Vortech based kits. Pulley, injectors, and tune, and make sure your charge cooling can handle it as well, and your clutch, and your brakes, and your transmission, and ........
| Thread Tools | |
