996 Forum 1999-2005
Shifter Trim Repair / Refinishing Results - Pictures and Description
Old 01-09-2010, 10:21 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Default Shifter Trim Repair / Refinishing Results - Pictures and Description
There have been a couple threads recently on this topic, so I thought that I would document my attempt to refinish my trim ring around the shifter.
The finish on the U-shaped silver trim that surrounds the shifter boot on the 996 (1999 C4 I my case) starts to bubble and lift, as you can see from the pictures.
While I had read that it would require a full replacement the boot assembly (over $250) as the trim is an integral part of the boot assembly, I decided to try to remove and repair it.
Trim removal from shift boot assembly
It is possible to separate the trim from the assembly. Six plastic studs are molded into the back side of the trim to hold it in place in the boot assembly. Starting at the open end of the “U”, I pushed from the backside and lower part of the trim. It took some time to work them free and separate it. Go slowly, be firm, but gentle.
Removal of old trim finish
The trim is a piece of U-shaped plastic covered in a foil-like silver finish. It is this finish that was bubbling.
Starting where it had bubbled up, I used a sharp knife to peel the old foil off. This can be time consuming because the foil adheres quite well where it is not bubbled. Using a sharp blade (razor or x-acto) flush against the surface allows you to peel back the foil enough to use your thumb and forefinger and pull it off in small to medium-sized strips. I also found that if you do this at the edges of the tri, you could get larger edge to peel off. You want to be careful not to gauge the surface as this will likely show through when you paint it.
I removed 100% of the foil from the visible portion of the pieces, all of the edges, but could not get about 15% to 20% of the foil on the inner (concave) portion of the trim piece to come off and did not think it was necessary to spend any more time.
Refinishing
Preparation - Very lightly sand the outer surface of the piece with 220 grit (I did not have any 360 or 400) to rough up the surface and smooth any knife marks. Wipe it down with a damp rag to remove the sanding dust and then wipe with a rag dabbed in a small amount of acetone to clean the surface. Prime with Dupli-Color grey primer – 3 light coats.
Finishing – Finish with 3 coats of Dupli-Color VW Diamond Silver (P/N 8802029) and 2 coats of clear coat. (I took the trim to the store and VW Silver was the closest match).
Reinstallation
The trim piece simply snaps back into place.
Conclusion
The silver is a pretty close match (the picture is not representative). The new finish lacks, perhaps, a bit of metallic lustre, but is much better than what was there.
Total time was about 1.5 hours, but it took about 8 hours with paint drying time.
peterp (11-03-2023)
Old 01-09-2010, 10:26 PM
crcjr1963
crcjr1963's Avatar
Nice work!
Old 01-09-2010, 10:51 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Very nice job!
Old 01-09-2010, 11:27 PM
gota911
Newbies Hospitality Director
gota911's Avatar
Good job! Thanks for the write-up and pics!
Old 01-10-2010, 12:17 AM
Chaos
Chaos's Avatar
Sharp,so easy a caveman could do it !
Old 01-10-2010, 01:08 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,259 Likes on 790 Posts
Looks really good!
Old 01-10-2010, 08:42 AM
Barn996
Barn996's Avatar
Nice job and great pics...thank you!
Old 01-10-2010, 03:51 PM
okbarnett
okbarnett's Avatar
I have a better color match for the interior silver trim.
its a Plastic-kote spray can at auto parts stores
Bumper and Trim silver metallic, #1897
I painted several of my interior pieces to match the stock parts
Old 01-10-2010, 04:09 PM
ivangene
Parts Specialist
ivangene's Avatar
wow, that looks WAY better!
Old 01-10-2010, 05:05 PM
Rickker
Rickker's Avatar
Well done, Fergus!! Looking forward to seeing it in person soon.
...Rickker
Old 01-10-2010, 06:13 PM
buzztt
buzztt's Avatar
nice work
Old 01-10-2010, 06:23 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Thanks for all the kind words
Not available in Canada and I would suggest that you would be hard-pressed to tell the difference in person.
Old 01-12-2010, 01:59 AM
jasper
jasper's Avatar
Nice work Canuck.
I just noticed the other daymine was starting to bubble and was thinking of doing the same thing.
Is it time yet to update the sig and the avatar by the way??
Old 01-12-2010, 05:19 AM
Pac996
Pac996's Avatar
Job well done. Do you know of a good leather dye for your leather? I've got the same leather interior but it seems my steering wheel is getting used much more.
Old 01-12-2010, 09:20 AM
fbgh2o
Odd Posts
fbgh2o's Avatar
Good point... Done.
No I don't, sorry.
Quick Reply: Shifter Trim Repair / Refinishing Results - Pictures and Description
