996 Forum 1999-2005
New spark plugs - why didn't I have this done sooner??
Old 01-25-2010, 08:58 PM
AndyK
AndyK's Avatar
Default New spark plugs - why didn't I have this done sooner??
I had my mechanic install the new plugs I was going to do myself but decided I might need my back. So, I picked it up tonight. AMAZINGLY better comes to mind. The engine is quieter, smoother, more responsive, sounds healthier, the car is easier to shift smoothly. Someone said it best - transformationally better!
My old plugs only had 20k miles on them, so most would say "why change them"? If you have original plugs, CHANGE THEM (or pay someone to do it)! You will NOT be sorry!
Old 01-25-2010, 09:28 PM
Barn996
Barn996's Avatar
Good post...so you really noticed an improvement? I need to do my plugs next.
Old 01-25-2010, 09:54 PM
sheatley
sheatley's Avatar
Did you notice the condition of the plug- gap size, wear of tip? Same plugs?
When I have done plugs on other vehicles, I usually did the air filter at the same time. When the vehicle improved, I was never sure which affected the performance: plugs or clean filter.
Old 01-25-2010, 10:45 PM
AndyK
AndyK's Avatar
I didn't see the old plugs, but I notice subtle differences - and this was a MAJOR improvement!
Old 01-25-2010, 10:51 PM
rxjohn
rxjohn's Avatar
I'm going to do my sparks after IMS retrofit. I hear it's a 6 to 8 hour job...
Old 01-25-2010, 10:54 PM
ivangene
Parts Specialist
ivangene's Avatar
While your mufflers are off - swap in a set of FisterD's
Old 01-25-2010, 11:05 PM
jrgordonsenior
jrgordonsenior's Avatar
BS....
Old 01-25-2010, 11:24 PM
rxjohn
rxjohn's Avatar
Originally Posted by jrgordonsenior
BS....
I hope you're right. Because I really don't want to spend that much time changing sparks... How long you think?
Old 01-25-2010, 11:45 PM
Melchior
Melchior's Avatar
Make sure you remove the mufflers (do a search for procedure, easy) and you can do the job in under an hour. Also prevents you from damaging the coil packs, which can be costly!
Old 01-25-2010, 11:52 PM
ivangene
Parts Specialist
ivangene's Avatar
first time muffler removal is about an hour and a half tops.... after that you can do it in 15 minutes off and 15 back on....
Old 01-26-2010, 06:55 AM
AndyK
AndyK's Avatar
My mechanic billed me for 2 hours. I was going to do it myself, but figured that it only has to be done once, and I didn't have the desire to get the car up on jacks and fiddle with the mufflers for an entire weekend morning or afternoon.
If you have the time, go for it. You'll like the results!
Old 01-26-2010, 08:12 AM
Barn996
Barn996's Avatar
+++1
Old 01-26-2010, 07:32 PM
sparks259
sparks259's Avatar
what are fister d's?
Old 01-26-2010, 07:52 PM
Pac996
Pac996's Avatar
One of the guys on here does an exaust bypass trick. Link bellow.
http://www.fdmotorsports.net/
Old 01-27-2010, 04:01 AM
jasper
jasper's Avatar
Nice tip...it's on the spring maintenance list.
Quick Reply: New spark plugs - why didn't I have this done sooner??
