Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-29-2010, 12:15 PM   #1
smithk993
User
smithk993's Avatar
Default Adjusting Parking Brake, Require removing console?
My parking brake in my new to me 996TT pulls almost vertical before it will hold. I want to try and adjust to 3-4 clicks.
Can you get to the cables without removing console completely? I've got the factory CF unit so I don't want to do any more than required to minimize potential damage to console.
Thanks.
smithk993 is online now   Reply With Quote
Old 01-29-2010, 12:26 PM   #2
ivangene
Parts Specialist
copy from Loren
The parking brake uses two drum brakes that are on the inside of the rear brake rotors. There is a typical drum brake adjustment (for the shoes) on each rear rotor. Adjust with a large screwdriver through the hole in the rotor hub (wheel off). Rotate the adjustment until the rotor can not be turned then back off 5 clicks (rotor should turn freely).
The parking brake cable is adjusted in the center console by removing the plastic plate in the storage bin. Using two wrenches release the lock nut and then tighten the nuts to adjust the cable. A correct adjustment will NOT actuate the parking until 5th click. Anything may cause the brake shoes to drag and cause premature wear on the parking brake shoes. Don't forget to tighten the lock nut again when your adjustment is complete.
ivangene is offline   Reply With Quote
Old 01-29-2010, 12:26 PM   #3
10 GT3
Super User
10 GT3's Avatar
Yes, you can adjust them without removing the console. There are actually 2 ways you can adjust them: at the handle and at the adjusters on the brake shoes. From the position on your handle, I would strongly recommend that you pull your rear wheels/rotors and check how much surface is left o nthe parking brake shoes. If they are worn down, a new set of shoes should make the handle correct. to adjsut the handle directly, open the storage bin and pull out the rubber piece at the bottom. Remove the single Torx head screw that holds the cover plate. You can now use a wrench to adjust the cable tension. If the cable holder is tiilted to one side, you need to adjust the adjuster on the brake where the cable has slack.
10 GT3 is offline   Reply With Quote
Old 01-29-2010, 01:26 PM   #4
ivangene
Parts Specialist
BTW - Porsche knew we might need to adjust certain things and replace some items - so they made it pretty easy to do so.... Those of you that DIY can confirm that although there is often hard to work on parts, there are also many very easy to access items......
Dont be afraid to try the simple jobs (ask if you dont know how as the OP did) but most of these little things are easy to fix yourself.......
Old 01-29-2010, 04:23 PM   #5
smithk993
User
smithk993's Avatar
Great information. I'm thinking that the shoes may be worn out beacuse the handle comes so far up. I will try and pull the rear rotors and have a look. Assume what could have worn out parking brake of a 27k mile car would have been failing to release the parking brake.
Keith
Old 01-29-2010, 04:54 PM   #6
smithk993
User
smithk993's Avatar
I found the following DIY for replacing brakes.
http://www.6speedonline.com/forums/9...e-replace.html
Could someone reference one of the photos and tell me where I'm supposed to insert a screwdriver to get to the adjusting screw for the shoes? Where is the screw located. Don;t think you can see it with the rotor on.
Thanks. I'm sure it will be more obvious once I pull off the wheel but it may be next week when the snow melts!
Keith
Old 02-01-2010, 06:44 PM   #7
smithk993
User
smithk993's Avatar
Well I got the PB adjusted. I thought when the DIY said insert screwdriver through lug nut hole that I would find a screw to turn to tighten/loosen the springs. Turns out it's not a screw head but a knurled **** that you kinda ratchet using the tip of the screwdriver. I turned it counterclockwise to tighten. As instructed, I tightened until the rotor wouldn't turn by hand and then backed off about 5 clicks. Handle now comes up only about 45 degrees to fully hold.
Old 02-01-2010, 06:51 PM   #8
gota911
Newbies Hospitality Director
gota911's Avatar
Location: Greenville, SC ....... going to Winston-Salem, NC
Cool! Thanks for the update. This will probably help someone in teh future.
Tim K.
"Lurking About" no more!
Mods: Sharkwerks Center Muffler by-pass pipes | PSE | Ti Lug Bolts | Porsche Short Shifter
gota911 is offline   Reply With Quote
Old 02-01-2010, 10:20 PM   #9
RallyJon
Weathergirl
RallyJon's Avatar
A tech article on 6speedonline that doesn't involve 20" deep dish rims or 57 responses of "props to ya' bro'". I'm deeply impressed.
02 996 C4S · 95 993 C4 · 911 RS look · STI · S4 · rally car
RallyJon is offline   Reply With Quote
Old 02-01-2010, 10:45 PM   #10
Torontoworker
Torontoworker's Avatar
Quote:
And if you act now there is a service special at NY dealers where it's only $695.00 to do this service - but you have to act now.
1999 996 C2
2004 Honda Shadow Classic
2005 Suzuki SV650S
2008 Sebring Cab
2012 Cadillac Coupe
Torontoworker is offline   Reply With Quote
Old 07-31-2010, 03:38 PM   #11
robf
New User
Default Great Video on Adjusting the E-Brake on a 996 (997 is similar)
Check out this video on adjusting the e-brake. Very helpful.
http://www.youtube.com/watch?v=9DpC0...eature=related
robf is offline   Reply With Quote
Old 07-31-2010, 03:55 PM   #12
peavynation
peavynation's Avatar
Quote:
LOL!
'01 996 C4, Ylw/Blk 6sp Aero
'67 Mustang Fastback, 390FE S-code 4sp (now with TCI C6) Video
'70 Mustang Mach1, 351C 4V M-code 4sp (now w/ worked 2V's & T5)
'95 Toyota T-100 Pickup, V6, mild lift
'05 Suzuki SV650S, (transformed into a ring on my wife's finger)
'03 Honda CRV
'89 Nissan Stanza (yellow bumper as paint came off!! Awesome)
'84 Toyota SR5 Pickup
'78 Chevy Stepside 4x4 w/ 1ton trans/T-case/axles
'75 IH Scout, Orange
peavynation is offline   Reply With Quote
Old 07-31-2010, 04:01 PM   #13
peavynation
Quote:
'03 Honda CRV
Tags
2006, 911, adjust, adjusting, adjustment, ajustment, boxster, brake, cable, cayman, emergency, handbrake, parking, porsche, savannah
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
