Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 02-21-2010, 04:04 PM   #1
Dervish
Dervish's Avatar
Thumbs up Girodisc rotors finally installed
Upgraded the front rotors from OEM cross drilled to Girodisc slotted.
The Girodisc are 8% larger (340mm vs 317mm) and fit using the stock caliper with a reduction in weight from 9.0kg to 7.8kg per disc. The increased diameter provides a larger effective radius giving more braking force for the same system pressure. I really didn't want to go down the Brembo BBK route requiring almost a complete new disc/caliper system and pressure/bias changes.
Here you can see the quality...
And here the size comparison with the OEM...
It's a very easy install, the only difference to the usual disc change is the addition of the 12mm spacer to move the caliper further away from the arm. The spacers are included in the kit together with 12mm longer caliper bolts (strangely Porsche part numbered?).
Finished...
Thanks to Craig at rennstore for all the info and help...
Now I just have to see how they compare on track...
Dervish is offline   Reply With Quote
Old 02-21-2010, 04:10 PM   #2
ivangene
Parts Specialist
SWEET !!
ivangene is offline   Reply With Quote
Old 02-21-2010, 05:33 PM   #3
LVDell
LVDell's Avatar
Looking good! And I'll bet you are going to be even more excited to know it's more than 8%. **hint....area of a circle not difference in diameter**
LVDell is offline   Reply With Quote
Old 02-21-2010, 07:31 PM   #4
redridge
redridge's Avatar
Im assuming the longer bolts comes with the kit.... looks great! The spacers are a bit cheesy though.
Ferdinand
redridge is offline   Reply With Quote
Old 02-21-2010, 07:41 PM   #5
2K3TTMIA
2K3TTMIA's Avatar
Quote:
+1, maybe an entire single billet piece to cover the caliper contact area.
2K3TTMIA is offline   Reply With Quote
Old 02-21-2010, 08:03 PM   #6
redridge
redridge's Avatar
Quote:
yup.... that'll be a winner! The way it is... it looks like the caliper will run hotter than the stock setup, just my guess.
Ferdinand
Old 02-21-2010, 08:22 PM   #7
ivangene
Parts Specialist
anyone interested in having me make a one piece?
Old 02-21-2010, 08:28 PM   #8
redridge
redridge's Avatar
Ed, you might want to talk to the vendor..... this might be a good option for some. If I was in the market, I will def give you a call.
Ferdinand
Old 02-21-2010, 10:14 PM   #9
Shark Attack
Shark Attack's Avatar
that looks like a mod worth while and easy. I agree on the spacers. I think a nice one peice spacer that looks like it is supposed to be there would be better.
Kyle
99/911 Aerosmith 6 speeder
I also have a strong respect for the 928.
=> another good forum http://reutterwerk.com/forums/forumdisplay.php?f=60
Shark Attack is offline   Reply With Quote
Old 02-21-2010, 11:12 PM   #10
FLY996
FLY996's Avatar
makes the calipers look to small...
FLY996 is offline   Reply With Quote
Old 02-22-2010, 02:12 AM   #11
Dervish
Dervish's Avatar
Why would a one piece spacer be any better? It's just added weight, you're not doing it for looks as it's never seen. The spacer design is perfect for the application and has been race tested.
I agree on the caliper size thing hence keeping them black, red would stand out too much, but it's only marginal. Like I mentioned before though if I wanted bigger calipers etc I would have gone down the GT3 6pot route but then you're talking $1000s more...
Old 02-22-2010, 08:56 AM   #12
Barn996
Barn996's Avatar
Let us know how the new rotors perform compared to OEM without upgrading the calipers. You are probably doing this for the track as opposed to street use? They look great.
MY99 996,C2 Coupe,LSD,black/savanna beige, 6 spd., US MO3O suspension,black 3 spoke steering wheel,leather sport seats,TC, rear seat delete,ashtray delete, FisterD exhaust...current miles 59k Barn/Steve
1999 996 C2(current)
2002 Audi TT(history)
1998 Audi A4 "
1979 911 SC "
1986 Saab SPG "
1968 912 "
1960 AH Bugeye "
Barn996 is offline   Reply With Quote
Old 02-22-2010, 11:28 AM   #13
2K3TTMIA
2K3TTMIA's Avatar
Quote:
First and foremost, the rotors look badazz and like quality pieces..I pm'd craig myself and am interested in the upgrade vs cost factor...
I'm not an engineer, but I have been wrenching for 28 years on everything from beaters to hi-performance muscle cars. The single piece spacer for one allows for a solid contact between the caliper and the mounting surface. I haven't witnessed the effects of heavy braking on these items first hand, specifically on P-cars, but I imagine there are some forces involved and alot of heat generated.
I would think you'd want to spread some of those forces and heat uniformly from the caliper, not just thru those two 12mm thick washers. the air moving in that gap is not going to do squat to have a cooling effect.
my other .02...
- and the spacers look cheesy.
Old 02-22-2010, 12:59 PM   #14
LVDell
LVDell's Avatar
Curious why they would not make them as direct replacements to the stock unit and not require the spacer.
Has anybody that purchased these MEASURED the rotor area and compared to the stock units? In other words, measure the width of the rotor that is from that area where the hat ends and the rotor edge ends.
Old 02-22-2010, 01:09 PM   #15
redridge
redridge's Avatar
just looking at the pics... the stock is def smaller. It will be hard to make a 2 piece the same size as the stock.
the stock is 317mm vs 340mm... so the radius is longer... the advantage with this rotor (aside from heat dissipation?, fade etc? weight) is since the pads are further out, the stopping power is greater (more torque).
Ferdinand
Tags
964, calculate, disc, dissipation, giro, girodisc, girodiscpdf, heat, manufaturing, oem, porsche, red, rotor, rotors, rusting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
