New Clutch and Flywheel and still slipping!
Did the spring removal mod on the clutch pedal of my 2000 996 last week. Thought the clutch was starting to go prior to this and it did a few days later. Took it to my indy who I have little experience with. $1300 for a clutch job. Calls me and says it looks like the clutch was replaced recently , but the flywheel is scored beyond repair. Ok, so new dual mass flywheel, sachs clutch disc and pressure plate, flywheel pilot bearing, upgraded RMS and fix a window regulator too. While i'm going broke had him change the plugs as the electrodes on the one he pulled for me were flattened out and looked original. $3155 total.
Picked the car up as the shop was closing at 5pm. He says he drove it with the spring mechanism on it and off and liked it better without it so gave it to me. Thought it was ready to wring out . I test the window that he replaced the regulator on and it isnt as smooth as before it went out. I show it to him and he says to exercise it some and if i dont like it bring it back. Thats the easy part. I drive the car for 10 miles and the clutch is not right. As I shift through the gears the rpms continue to rise as I shift with my foot of the throttle and the clutch depressed. Didnt do that before. Then it does'nt pull like before as I go from 1st to 2nd. Lastly, as i run at 4000 rpm and stomp it , it is clearly not hooking up like it did before either.
Of course , by the time I got back to the shop at 530 , its closed. I am livid to say the least. Now I will be at his door when he opens and try to be amicable, but I am not warm and fuzzy with this guy. I thought he was solid as I took the car to him when i first got it and got an oil change and had him check it out. I should have researched more before finding a good pcar mechanic. He has a 930 turbo of his own, but works on Jag, MBZ and BMW as well. My mistake. I have since found someone in San Clemente who is supposedly the best around , but here i am.
Furthermore, I asked him about the cruise control and adding a spacer since the pedal spring was removed and he said it should work now. Not so. Upon inspection I found the cruise switch unhooked and looped under a loom to the side.
Any advice. I think I'm going to puke.
he sounds like a butcher.... have him fix it till you are satisfied not paying anymore than you already have. He might of fumbled with the pedal potentiometer which is located under the dash. I found that removing the helper spring is not good enough since it leaves slop on the pedal and has a tendancy to not make contact with the CC switch, making it useless. I installed a weaker helper spring just enough to get rid of the slop but not strong enough to make the pedal feel to light....
once he fixes the problems......write him off!
Really doesn't sound good. The manual says checking end position there shouldn't be any movement when pulling back on the pedal. I guess redoing the boost spring would make slack there. I'm still a little confused after reading some of the brake fluid bleeding is done at the clutch slave cylinder bleeder.
Is there a difference in slipping between first start cold and after warmed up?
clutch is REALLY simple. Not may things there to go wrong. Only one I can think of that a person **might** be able to do is put the disc in backwards. other than that, he really didnt do the work, the pedal is hanging up or the slave is acting goofy.
Exercise it = get the **** outta here, I dont know whats wrong with it and I wanna go home. or, Yeah a saw that, but I want paid, so here is a bone, now pay me and I will jerk you off again in 30 days.
If your car is a pre April 2000 build, you may have the old design of the release lever which is known to casue slippage. Sounds like you have a bigger problem but the lever should have been replaced also.
Good news
Well after a long night of stewing on my problem, I calmed down and finally got the clutch pedal return spring assembly back in. Guess what? The clutch now works like it should. I have the old flywheel and clutch assembly and it looks like there was 50% of the disc left. Now i have a new flywheel and rms, but no confidence in the guy who did the work. I did hot laps for an hour and I am happy. I guess it was a $3ooo lesson on being very selective and doing my research on a mechanic before giving him my car. I will take the car elsewhere to have the window fixed right, because i want this guy nowhere near my car.
Redridge, you mentioned the potentiometer under the dash. Does removing that spring affect its operation. In my case it appears it did. It came out easy enough, but putting it back in was frustrating until i slept on it and went back to it with a clearer head. A cut up head, but clear. Ok, got to go work some more to pay for my stupidity.
Thanks again for the replies and input, I appreciate it.
I guess that Indy really sucks, sheesh
I find it amazing that once you replace the return spring all the problems went away and the car was actually 100% the whole time, yet it is still his fault. Something to think about.
Also, x100 on needing the release lever on the earlier cars.
Kind of seems some of the designed clutch engagement pressure is derived from the hydrolics system if the clutch pedal not returning all the way doesn't cause a good lock up.
There is also possibly high ratio of pressure derrived from the slave cylinder which just a little bit of pressure on the system from the pedal pressure would cause a little disengagement. I know a guy shouldn't even rest a foot on a clutch pedal or risk burning the clutch.
