Aftermarket Air Filters- Oiled vs. Non Oiled.
I've used the search for previous and a ton of info, but no real data/feedback on which might be better or safer.
I know there are 2-3 popular aftermarkets intakes out there right now, some use the K&N and some the newer cone that is a dry material.
Is the final result of the oiled is that it will eventually mess up the MAF? I know others running the oiled K&N with no probs , or should I stay with that Synthamax "dry" material?
thanks anyone.
thanks anyone.
Parts Specialist
K&N reps have stopped by here and stated over and over that they have tested thier product and never had any maf problems from them.
RL members claim they have had issues with them
some still run them
the K$N kit is a tin can piece of poor engineered junk.
EVOMS looks like a better system
stock is bullet proof, cheap and works
some still run them
The 928 guys say the K and N is good for a track car but not a DD. They say they do breath better but they also let larger particals in to the engine. They also complain about the oil/maf thing. honestly. How can not NOT ef up your MAF?
Would you rather breath through a dry filter or one wet with oil?
I've run oiled K&N filters on three cars over the past 15 years. No MAF problems, no excess contamination in my oil analysis, and more power (at least on the one vehicle I dyno'd with and without it).
Run a K/N in every car Ive owned for the last 13yrs not a single Maf failure in any car. I think its a big scare tactic....silicone will ruin a maf, not oil.
Weathergirl
There's not a big debate on this. The freer flowing filters let a lot more particles into the engine. Does this happen? Absolutely. Does it bother you? Some say yes, some say no.
Weathergirl
Wrong there: http://www.bobistheoilguy.com/airfilter/airtest3.htm
But again, it's all about your tolerances, and what you want to believe. If you'd like to run a K&N, there is ample anecdotal evidence to support whatever cognitive dissonance you need to manufacture to help you sleep at night.
I had a K&N on a previous car, was there when I got it. Close to 13 years and 170k Km (105K miles). Accelerated engine wear? maybe, no MAF problems though.
Robert
Robert
I've had MAFS fail on cars with paper filters. I've had cars with oiled filters that never had a problem. On the Porsche, there's an oiled filter on my EVOMS intake, and engine oil analysis every couple of years doesn't suggest there's any premature wear or intake impurities. It just doesn't seem worth worrying about, to me. The two things that are often absent from this debate are a) MAFS are consumables, and b) a lot of people over-oil their filters and then want someone to blame for the outcome. I just get mine serviced by someone who's less of an ***-hat with tools than I am.
