996 Forum 1999-2005
Leaking water into cabin
Old 06-15-2010, 10:58 PM
StephenB
StephenB's Avatar
As stated earlier, clean your drains. If you have an early 996, make sure the drain grommets have been updated per the TSB. The slots keep debris from laying flat and plugging the orifice completely. Check your VIN window to make sure you have the clear plastic cover in place. it only take one small leaf to plug the drain on the passenger side if these updates have not been applied.
Old 06-16-2010, 08:56 AM
RPMulli
RPMulli's Avatar
mine doesnt have a window, its just a black plastic cover, do you have a picture with the black plastic cover removed?
Old 06-16-2010, 10:53 AM
ivangene
Parts Specialist
ivangene's Avatar
with the cover off the filter is right there...nothing on it....normal
Old 06-16-2010, 10:58 AM
roadsession
roadsession's Avatar
what is that blue thingy
Old 06-16-2010, 11:03 AM
number9ine
number9ine's Avatar
Looks like Ed's recharging his AC.
Old 06-16-2010, 01:27 PM
RPMulli
RPMulli's Avatar
oh i dont have that little plastic black cover on the passenger side of my filter, i bet that is where the water is coming in.
Old 06-16-2010, 01:28 PM
RPMulli
RPMulli's Avatar
what is the part # on that tiny plastic shield?
Old 06-16-2010, 01:29 PM
RPMulli
RPMulli's Avatar
nevermind i got it, it is actually part of the housing. 996 572 019 02 . ugh $83....fail..
Old 06-18-2010, 11:03 PM
RPMulli
RPMulli's Avatar
Got some pictures for you all..
I cleaned the drain out for the A/C condenser. It seemed clear but i think the water is building up in that general area. I really poured out today on the both the drivers and passenger sides after i ran the A/C for a while. any ideas anyone?
Old 08-04-2015, 12:35 PM
vbcracer
vbcracer's Avatar
Use air to blow out the AC condenser drain. I had water in passenger footwell and that was the problem. Drain is above pass footwell and connects to AC unit.
Quick Reply: Leaking water into cabin
