Cleaning radiators
Cleaning radiators
Over the last year, my temp gauge has been creeping up a little... Although I try to regularly look in the air scoops and clean out any debris, I thought it was time to take the bumper off and actually clean the radiators.
I followed some good instructions on YouTube.
All I can say is, "Holy crap! There was a lot of crap in there!"
So, I made a video: why to clean them
Good job Van! I cleaned mine last month as well. My car runs a tick over 180 now. The clean radiators dropped about 8 degrees from operating temp. Definitely suggest doing this at least once a year.
Was stuck in traffic yesterday....what else is new...but temp barely hit the 0...turned on the AC kept the fans going and Im sure having cleaned the radiators a couple months back helped big time!! Not concerned about the heat as much now. Very happy.
Last time I cleaned mine, I took a hose to the radiators and cleaned the gunk off completely. How were you able to do that on the lift or did you take the car off the lift for that step?
I put the front wheels back on, backed it out of the garage, and pressure washed the radiators in the driveway. Then put it back on the lift to put it together.
I'd go as far as pulling the rads and condensers apart so you can thoroughly get what's between them. The PO of my car never did this. Over time, the leaves and crap in there soaked up brine from winter roads and actually rotted the radiators, causing both blockage and leakage. I had to replace both of them last year. Having no place to work on my car, I have to pay people to do stuff like this... it wasn't a cheap day. Word to the wise.
