996 Forum 1999-2005
No longer use Mobil1 0w-40?
Old 07-29-2010, 09:47 PM
  #31
BruceP
BruceP's Avatar
Originally Posted by Dharn55
So explain the use of 0W-40 when it is not even listed in the owners manual. I think there may have been some TSB's that list 0W-40, I will have to look, but it ain't in the owners manual!
My understanding is that those lists have been updated more than once since the manuals were printed, so I can't help you there.
My logic is a little different than yours. I think that film strength matters when the engine is stressed, but I don't stress my engine until it's warm. Whereas, the valve gear in these motors is super sensitive to lubrication, and the more easily it flows the quicker it will get it on startup. In other words, when cold, your variocam bits need oil fast more than your pistons need maximum protection.
Anyway, sounds like we're both bringing knives to this gunfight, so I'll leave it there. I'm sticking with what my indie puts in there.
Old 07-29-2010, 09:58 PM
  #32
Dark Helmet
Dark Helmet's Avatar
OK, new guy diving in here... I think I've read this same thread 79 times on bimmerforums (my home)...
the point is not that 0-40 is bad, its that mobil1 0-40 is too thin or doesn't have the right chem compound. this exact same issue came up when BMW delisted mobil1 0-30 from its approved list, but kept redline/amsoil/etc....
now, from there... if you're getting ANY tappet/lobe mushrooming, I'd suggest you cease using whatever you were using before and move to something a touch thicker at operating temp.
flame suit: ON!
Old 07-29-2010, 10:23 PM
  #33
roadsession
roadsession's Avatar
Originally Posted by BruceP
No. You don't.
cool
Old 07-29-2010, 10:24 PM
  #34
roadsession
OK btw: on my Merc and BMW : dealer only uses Mobil 1 0-40W
Old 07-29-2010, 10:27 PM
  #35
BruceP
BruceP's Avatar
Dark Helmet, "at operating temperature", any oil with a 40 at the end of its rating has the same viscosity. It can't be "too thin". That oil has a 0 viscosity when cold, and a 40 viscosity when warm. If you want a heavier oil at operating temperatures, it's the second number you need to think about, not the first.
People pronounce 0W40 as "too thin" and, with respect, they often seem either not to know what they're talking about or to be kind of imprecise in their language. It's why I usually avoid these debates. If you believe that 0 is too thin, you must by definition believe that it's too thin at startup. Because when it's at operating temperature, the viscosity isn't 0. It's 40.
So I remain confused about why it's such a hot topic...
Old 07-29-2010, 10:51 PM
  #36
C4CRNA
C4CRNA's Avatar
Less than ten hours on this post and only 3 pages!!
Old 07-29-2010, 10:56 PM
  #37
Hapich
Hapich's Avatar
I called LN eng. about 6 months ago when I first had my P car to ask about the IMS thing, sorry guys you put the fear in me, and they told me it wasn't that big of an issue for warmer climates. He told me to use Castrol Syntec 5W40 and not worry about it. That's a fact. No bull.
Old 07-29-2010, 11:01 PM
  #38
PasPar2
PasPar2's Avatar
NVM
Old 07-29-2010, 11:02 PM
  #39
RF5BPilot
RF5BPilot's Avatar
Checked the TSB's and found two from 2009 (both are listed as superseded, not sure why or by what) that list 0W-40 along with 5W-40 and 5W-50. They say for temps below 25C use the 0W-40.
What to do? What to Do? What to Do?
I am sticking with the 5W-40 and 5W -50 myself.
Actually, note that it says below -25C not 25C.
99% of this bantering is about the first few minutes after startup. After that, the oil thickens on its way to 40 weight.
My guess is that the times that 0 vs. 5 weight will matter are only in the coldest of conditions (e.g., below -25C) or if someone is stupid (desperate?) enough to slam the engine to high RPM's or high load immediately after starting.
I'd be willing to bet $$ that using your car regularly (so parts remain coated) and gently until it warms up -- will have more tangible, positive results than choosing 0 vs. 5 cold weight.
Old 07-29-2010, 11:07 PM
  #40
Sneaky Pete
Sneaky Pete's Avatar
Did someone say salt? I need some butter too......
Old 07-29-2010, 11:11 PM
  #41
PasPar2
PasPar2's Avatar
I think eveyone should just post the oil they use as part of their signature
Old 07-29-2010, 11:14 PM
  #42
BruceP
BruceP's Avatar
I agree with your last statement for sure. The cold viscosity thing is hair splitting to some extent. But it doesn't explain why people get so bent out of shape about it. Sure, you're probably fine with a 5 cold viscosity oil. 0 may not be necessary where you live, but does that mean there's anything wrong with 0? Not as far as I can see. Most of the objection to 0W40 seems rooted in a misunderstanding about what that number means.
Old 07-29-2010, 11:28 PM
  #43
ivangene
Parts Specialist
ivangene's Avatar
nothing like an oil thread to get things moving
Old 07-29-2010, 11:34 PM
  #44
Hapich
Hapich's Avatar
Oh, new avatar. Very sexy in an 80's kinda way
Old 07-30-2010, 12:21 AM
  #45
Pac996
Pac996's Avatar
The engine gets up to operating temp faster with out oil
Quick Reply: No longer use Mobil1 0w-40?
