Rear ended
I was rear ended today. I was stopped and the girl was going between 25 to 40 miles per hour. There is only visible damage to the bumperettes and two scratches on the bumper. My questions who shouldni take it To get checked out? Porsche dealer? Body shop? Both? I just want to make sure nothing shows up later on.
Other car no way going that fast. My 02 Boxster got rear-ended stopped at a light. Driver of car behind mine started forward when the driver -- "distracted" aka on the g*dd*mned cell phone -- seeing movement from car in left hand turn lane thought light changed in the lane she was in. It hadn't and she drove her car into mine. This shoved my car into new SUV in front of my car.
Impact speed about 5mph (I had recording device in car at time).
Damage was to front and rear bumper covers, some bumper bracing/metal under the rear cover. One taillight assembly. One headlight assembly.
A bit over $5K.
In CA you are entitled to take car to any shop you want to. Also, car is supposed to be restored to its pre-collision condition. You want this done to avoid any diminished value claim.
If body/sheet metal damage slight to none, consider taking the car to a dealer and letting the dealer's tech dismantle the damaged covers and other hardware. They are much better at this mechanical work than the body shop.
The body shop is good at painting and finishing but lousy at mechanical work.
New covers will be ordered and test fitted and then prepped and painted by a qualified shop. The shop wants to be a Porsche approved collision repair center.
Now in some cases if impact speed higher -- and I don't think it is high enough but I'm not the expert -- the car's wheels are removed, the car placed on a Celette Bench and various body/chassis hard attachment points checked for proper location. This finds if the car has been bent/twisting slightly - which I don't think will be the case -- or even if a bumper cover mounting bracket pushed a bit out of shape/position.
Porsche doesn't consider the car roadworthy after an accident repair until the car checked out by a qualified tech.
Oh, if you wish to keep the car's warranty intact, all parts must be bought through PCNA, ordered by and purchase from a qualified Porsche dealer, and all mechanical work done by a Porsche tech. PCNA/dealers do not discount parts cost to body shops. Tech labor is where I lived billed at $150/hour and labor is not discounted either.
But the entire vehicle's warranty remains in effect. This is very important. My 03 Turbo was damaged when I hit a mule deer with it I was told the above and took my car to a body shop recommended by a Porsche dealer. I insisted on all new parts and all mechanical work done by the dealer. Cost of repairs came to around $25K. No chassis/frame damage but these cars are not cheap to repair properly. Just recently some problems developed with radiator, fan/hub assembly of a radiator fan, serpentine belt idler roller bearing and transmission. All -- including transmission replacement -- covered by CPO warranty which remained in effect after accident repairs. Had the car lost its CPO warranty coverage, that accident would have cost me out of pocket expenses for those repairs of nearly $14K. (Transmission alone would have cost nearly $12K.)
Sincerely,
Macster.
I got hit at probably 15-25MPH in my 996 by a late 90's Ford Explorer. The road was a 45 MPH speed zone and the kid that hit me didn't realize I was stopped until probably 4-5 car links back. He hit me so hard I rolled into the intersection.
All that was damaged was the bumper shocks as Tim mentioned and a small tear in the bumper.
The 996 rear is pretty robust structurally wise; all panels lined up the same as before.
Sincerely,
Macster.
Now I think of it, it may have been like 2-3 car links back before he realized I was stopped.
Yeah, I know it helped I let off the brake because I knew he was coming without plans on stopping. I couldn't punch it (I sure would have) because cars were coming from the left turning.
Never ever punch it into an intersection even if you see a vehicle coming behind you. While the action seems reasonable, it is not. What will almost certainly happen is you pull out and either hit a car or a car hits your car. Very likely you'll be involved in a t-bone accident and these are the worst.
And the car coming up behind you of course avoids hitting you, manages to stop. Believe me *no* one will note the vehicle stopped where your's was, only that you pulled out on a red light into traffic and the accident will be your fault. You will have plenty of witnesses against you and one of them will be the driver of the vehicle that prompted you to pull out in order to avoid what you believed to be a sure impact.
Sincerely,
Macster.
That I had my foot off the brake pedal when my Boxster hit from behind may have helped reduce the amount of damage.
Sincerely,
Macster.
Sincerely,
Macster.
You were very lucky....because of the drama of it all(your baby getting hit) it seemed worst then it really was...you are allowed.....I had a 78 targa rear ended once and I saw it coming but could not get the car in gear fast enough to get out of the way......bummer.....
