Help Understand Components of OEM PCM/NAV
I've got a 2001 TT with the factory NAV unit. This is not the BOSE audio. I'm considering an upgrade to a aftermarket NAV/Audio system.
Does the OEM system have separate amplifiers? If so where are they located?
I'm not looking to have the top of the line audio system just a nice upgrade and a NAV that's a bit more useful than the factory system from 2000! What a joke.
Is swapping out the OEM double DIN unit and replacing with aftermarket a DIY project?
Could I use the OEM GPS antenna with aftermarket head unit, not sure where the antenna is located?
Thanks for the insights or maybe reference to some insightful posts.
K
K
Amp last known is on the wall of the trunk just above the spare.
Nav unit I'm not sure but I think there were updates on cd's for it.
There are manuals online in the UK.
