996 Forum 1999-2005
Clear fluid leak- rear passenger side..
Old 11-11-2010, 11:01 AM
Dharn55
Dharn55's Avatar
Too much and too far forward for a motor mount leak. 99% it is power steering fluid. At that point probably a leaking line/hose or the connections for the two hoses that are directly above where the fluid is showing. More pics would help.
Old 11-11-2010, 11:04 AM
joelpirela
joelpirela's Avatar
That's one of the problems with old cars with low miles. Hoses get brittle with no use.
Old 11-11-2010, 11:16 AM
nghiaho58
nghiaho58's Avatar
Originally Posted by Tarek307
Holly Freaking LEAK! Clear oily Fluid-Passenger side rear!!
I already posted this on 6speed so sorry for double post!
So i just came back from a quick trip to the store in my 2002 996 6speed manual-which i just bought 2 weeks ago only has 39k- i park and i look in the rear view and there is some smoke coming out the back (car driving normal, no lights, ect) i look under the car and notice a clear fluid is leaking, kind of an oily clear fluid- (engine oil level checked & this is not engine oil) its dripping onto the exhaust part and thats whats makign the smoke...then started the car again and when i did i noticed it was REALLY LEAKING like dripping out compared to just barley coming out after i stopped the engine..Great i've had this car a couple of weeks only.. now i have to worry all night as to what this **** is!
ps: LET ME REPEAT -COOLANT LEVEL IS NORMAL- CLEAR OILY FLUID DOES NOT SMELL LIKE COOLANT-COMING FROM PASSENGER SIDE REAR NOT DRIVERS SIDE!!!r -Also checked brake fluid in the front reservior and its full..the fluid is clear i let it drip on a napkin - its dark out which doesn't help
few photos! You can see in the second one while the engine was started that its like spewing out...****tttttttttttt
*****JUST CHECKED LEVEL ON THE HYDRAULIC FLUID CAP PENISTON STUFF & IT IS NOT EVEN SHOWING UP ON THE DIP STICK***Maybe the culprit here!
Since it is on the rear right side of the engine and the leaking fluid is clear, I would check the Power steering fluid reservoir or hoses for leaking. Check the fluid in the reservoir and the leaked fluid to see if they are the same color and smell. I hope it is not a big repair cost.
Old 11-11-2010, 01:47 PM
wwest
wwest's Avatar
Sunroof drain...??
Old 11-11-2010, 09:02 PM
Tarek307
Tarek307's Avatar
It ended up being the pentison fluid indeed- the O-Ring on the power steering hose line was pinshed for some reason & they replaced it- cost was $135 Pic below is of the line- its the right one!
Old 11-11-2010, 09:27 PM
ivangene
Parts Specialist
ivangene's Avatar
now your motor is clean
Old 11-12-2010, 08:47 AM
Barn996
Barn996's Avatar
Glad it's fixed and wasn't a major repair.
Old 11-13-2010, 03:21 PM
Tarek307
Tarek307's Avatar
Yes me too! Thank God Frank @ Becks auto in Scottsdale knew what it was right away & they fixed it fairly cheap!
Old 11-13-2010, 05:10 PM
Barn996
Barn996's Avatar
Feels great to have someone who can diagnose and repair so quickley. Another positive 996 post. Yea!
Quick Reply: Clear fluid leak- rear passenger side..
