996 Forum 1999-2005
Windows not going down and up
Old 11-13-2010, 11:37 AM
quimna
quimna's Avatar
Default Windows not going down and up
Hello guys, I have a 2003 996 TT, and my driver side window is not going down when open the door? Is there a way to reset this?
Any help would be appreciated,
Old 11-13-2010, 11:41 AM
RPMulli
RPMulli's Avatar
Does the other window work? Check fuses??
Old 11-13-2010, 01:00 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,228 Likes on 773 Posts
Do a search for "window regulator". This could be your issue if you are talking about the window not dropping down a little bit to clear the window seal. It could also be a micro-switch or other things, but I'd start with the search for a bad window regulator.
Old 11-13-2010, 01:12 PM
quimna
quimna's Avatar
Thanks! That is exactly what's happening !
I will look into it, thanks again
Old 11-13-2010, 02:45 PM
quimna
quimna's Avatar
i remember sometime ago (4-5 years) i had something similar happening to a 2002 911 i had. the dealer had me re-sync the windows. Has anybody done this? i can't remember what i had to do!
Anyhow, any help would be appreciated
Old 11-13-2010, 05:00 PM
DaveCarrera4
DaveCarrera4's Avatar
If you use the search dropdown at the top you will find all the answers. Check here for all the details: https://rennlist.com/forums/996-foru...door-open.html
Quick Reply: Windows not going down and up
