heated seat not working......
I have a 2002 C4S. Driver side heated seat is not working. When I press the button, red light comes on for a half second and then goes off.
Could there be a loose connection under the seat? My 6yr old daughter usually sits behind me, maybe her feet kicked a connection under the seat?
any thoughts or ideas on how to fix this?
thank you,
Glenn
thank you,
Glenn
I'd check the connection under your seat or it could be the switch. Don't have heated seats in my Porsche, wish I did today with the wind chill temp. at 7 degrees though. GL
Broken Element, it happend to me under CPO https://rennlist.com/forums/996-foru...t-working.html
Labor was 1.30 HR
Correction: RE and RE LF Seat. Remove Seat Back Cover. Dissassemble and Replace Seat Back Element in Cover
Parts:
1- 996-521-531-01 Backrest Cushion W/Heat $106 USD
1- 000-043-071-00 SECURING CLIPS $7.39
This is for the Comfort Seats
check this thread as well http://www.6speedonline.com/forums/9...ted-seats.html
Labor was 1.30 HR
Parts:
thanks. What does RE stand for? "Correction: RE and RE LF seat."
Labor was 1.30 HR
Parts:
Labor was 1.30 HR
Parts:
I just repaired my seatback element; one lead burned up and just required resoldering. Took about 30 min once I figured out how to remove the seatback cushion.
