Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 02-01-2011, 04:22 PM   #1
redridge
redridge's Avatar
Default 2nd gear detent (Gbox)..... pictorial DIY.
This is a DIY for the 2nd gear detent made by gbox... I followed their instructions here: http://www.gboxweb.com/detent.html
This DIY took me 1:15 min... can prob do it in 45min now that I know. There is a lot of feeling rather than seeing with this mod....as space is extremely limited. If you are clumsy or if you will be on your back..... forget it. Unless you are one of those young ones.... then go for it.
Kicking out wifey's car, she was not happy.... the wife not the car.
Click the image to open in full size.
See my finger? thats were the detent cover is.... right next to it is the cover bolt you have to remove first.
OK.... first thing, we need some space. Take off the last tunnel cover.
You need a 8mm for the cover bolt with a flex extension since you will be going at it at an angle. Go in from this side to get to the bolt.... this is not that bad.
Here is the bolt.... damn, thats a long bolt.
Next is the detent cover.... get an allen socket (13mm) and knock out the allen part with a punch and hammer. You need a short allen and a ratchet (the one that youve never used)
Put the allen on the detent cover and slip the ratchet on the allen..... I used a cheater bar to break the cover free.
detent cover off
Use the allen and a magnet to fish out the detent spring like this.
Again use the allen and magnet to fish out the detent..... tada!
Here's the OEM (left) and Gbox.... when you slip the detent back in the tranny, the wheel pin must be 90deg from the tranny side (or facing the side of the car). You can wiggle the shifter a bit and it will move the detent.... this is in its normal position.
Reverse the procedure.... button everything up. Put a blue loctite on the cover for a little seal.
Clean up and grab a beer.
Next Mod..... reverse light switch on the tranny. My light does not work.
To remove this ad, register today or login if you already are registered!
Ferdinand
redridge is offline   Reply With Quote
Old 02-01-2011, 04:50 PM   #2
Ubermensch
Ubermensch's Avatar
Thanks for the pictorial. I thought this was primarily and issue for the turbos. Were you having problems?
You'll actually enjoy replacing the reverse switch. It's literally the easiest thing I've ever repaired on any car.
-Shawn
Ubermensch is offline   Reply With Quote
Old 02-01-2011, 05:06 PM   #3
redridge
redridge's Avatar
-Shawn
Ive experienced a 2nd gear pop out in the cold a couple of times intermitently, it wasnt bad at all.... this is more preventative before it turns into a problem... The pop out is not that common... more so in the turbo, but it does happen in the carreras'.
Been wanting to change that switch forever.... now that it is exposed, its a good time to knock it out.
Ferdinand
Old 02-01-2011, 05:19 PM   #4
Sneaky Pete
Sneaky Pete's Avatar
Send a message via AIM to Sneaky Pete
Nice job. Those are some tight working quarters. I was just reading about the 'back up light' DIY on Renntech. Mine doesn't work either.
Pete
Current
1999 996 C4 Aero Artic Silver/Metropol Blue, Fabspeed, CAI, B&M SSK, X74 suspension, RS Motor Mounts, LN Stuff, FVD Deep Sump Pan and Daily Driver
2007 Audi A4 Quattro Black 2.0T
Past
1986 Carrera
1967 911
1974 914
1973 BMW 2002
1987 X19 Bertone
PCA Member
Sneaky Pete is offline   Reply With Quote
Old 02-01-2011, 08:09 PM   #5
RPMulli
RPMulli's Avatar
Thanks for the write up!! The OEM detent looks identical to the new one. Also, did you feel any difference in shifting?
Ryan
PCA Member
2000 996 C2, EVOMS Stage 2 Kit ECU & V-Flow CAI, No PSM, LNE IMS upgraded, 3.6 cans w/ PSE hack, H&R springs
2008 Volvo XC90 V8
2003 Audi Allroad 2.7T2000 Audi A6 Sedan 2.7T
2001 Audi S4 2.7T Stage 2
My IMS Replacement Thread
http://forums.rennlist.com/rennforum...-complete.html
RPMulli is offline   Reply With Quote
Old 02-01-2011, 08:17 PM   #6
redridge
redridge's Avatar
Quote:
dude... its like a ice skating rink out there. Gonna wait till this thaws out, Im not expecting anything different in shifting though.... just no more pop out.
There is a tiny difference between the two.... thats why these are supposed to work, the OEM tolerance are to tight.
Ferdinand
Old 02-01-2011, 09:49 PM   #7
RPMulli
RPMulli's Avatar
Awesome, I can't wait until it gets warm out to upgrade mine.
Ryan
PCA Member
2008 Volvo XC90 V8
Old 05-23-2011, 08:05 PM   #8
logray
User
logray's Avatar
Quote:
Originally Posted by tariq911 View Post
1- the cat at low RPM is so slow and heavy, maybe i am not usedto porsche but i have a frind expert with porsche he gave it a try and he told me this is not a porsche. the only error code from the engine is (cam shaft).
2- suddenly i started to face problems with the gear, on both tip and auto when i give a gas fro 1st to 2nd the gear pops, its like a gap in shfting ans the psm starts flashing. its very clear in the 1st to 2nd gear, but i think the problem is in all shifts.
1. Any cam shaft related DTCs are usually serious and should be addressed. Perhaps worn pads or variocam actuator mechanism. Or worse. If you can get the DTCs from the car you can get more exact diagnosis.
2. IIRC the detent is for G96 manuals only, not A96 tips. You should check your trans fluid level. It is possible there is some mechanical problem or perhaps the torque converter is worn.
Best thing to do would be to create a new post (or two), one for your trans issue and a second for the trouble codes your car is throwing related to the cams.
logray is offline   Reply With Quote
Old 05-23-2011, 08:36 PM   #9
Axeman
Axeman's Avatar
Thanks for the write-up my wife's 996 also suffers from the occasional 2nd gear pop-up so I'm getting to do the same thing on her car. This will help!
MJ
Current cars:
1989 C4 converted to C2 VRAM project
1999 996 C2 (Wife)
1972 911T Targa (3.0L with custom EFI)
1999 Boxster (Sold)
1975 C2 Turbo body with 3.0L - SOLD (but not forgotten )
Axeman is offline   Reply With Quote
Old 05-24-2011, 02:22 AM   #10
Ahmet
Ahmet's Avatar
Send a message via AIM to Ahmet
Out of curiosity, has anybody measured the factory shifter detent vs. the replacement? I'm curious how close they are...
Ahmet is offline   Reply With Quote
Old 05-24-2011, 02:28 AM   #11
chsu74
chsu74's Avatar
Quote:
I replaced mine with Ferd's help about a month ago. The difference is very minimal. An extra 1/32 of an inch maybe at most. The challenge in my install was tranny fluid created a vacuum when trying to pull the detent out. Ferdinand worked on it for over one hour just trying to remove the stock part.
Chao
97 993TT 2WD
01 325XI
09 GL320
chsu74 is online now   Reply With Quote
Old 05-24-2011, 02:46 AM   #12
Ahmet
Ahmet's Avatar
1/32nds of an inch in which measurement/is the replacement narrower or shorter?
Old 05-24-2011, 02:57 AM   #13
chsu74
chsu74's Avatar
It's the inside hole gap taller IIRC. I used to feel a big click shifting into second gear when the tranny box is cold and my shifts were more deliberate holding the shifter into second longer. Now the click is not as noticeable and slots into second easier. I do have a b&m short shift which makes the action harder than stock.
Chao
97 993TT 2WD
01 325XI
09 GL320
Old 05-24-2011, 03:57 AM   #14
Ahmet
Ahmet's Avatar
Inside hole is taller? I appreciate the feedback, but not sure I'm following you?
Old 05-24-2011, 06:49 PM   #15
carcster88
User
carcster88's Avatar
Thanks much for the info. I replaced my reverse light switch, now need to do this next. I have the 2nd gear pop put only when the car is cold, but would rather take care of it now.
carcster88 is offline   Reply With Quote
Paid Advertisement
Tags
2003, 996, a4, audi, back, box, boxster, detent, diy, escape, ford, gbox, interesting, light, mod, shift, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
