996 Forum 1999-2005
SET UP DISTRIBUTION AT MY 911/996 2003 ENGINE PLEASE!!!
Old 02-25-2011, 07:12 PM
carrera911/996
Cruisin'
carrera911/996's Avatar
Default SET UP DISTRIBUTION AT MY 911/996 2003 ENGINE PLEASE!!!
Hello,
I have a 911/996 2003 carrera and last summer i was running with it out of oil but not so long to damage it too bad.So i tried to rebuild the engine so i have bought all the damaged pieces.The axle,bearings,pomps and everything.Now i put all in order but i hardly try to find someone which know how to set up the distribution because i hared that is an order how to put the crankshafts and the chain.Please someone help me i am in a desperate situation because i have broken one crankshaft already because i didn't put them well in order and i already bought a new one so i don't want to do the same mistake again.
thank you very much.
Old 02-25-2011, 07:25 PM
RPMulli
RPMulli's Avatar
Are you for real?
If you are, sounds like you need to find a mechanic asap. Or the engine is scrap.
Old 02-25-2011, 09:46 PM
Shark Attack
Shark Attack's Avatar
wow... In more ways that one. Where are you located?
Old 02-25-2011, 09:50 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Uncle Leo??
Old 02-25-2011, 10:44 PM
Down South
Down South's Avatar
This is going to be interesting...
Old 02-25-2011, 11:37 PM
fpb111
fpb111's Avatar
From one of his Pelican posts. Don't we have someone from Romania on here?
"yes why is a joke.I am from romania and i tried to repair it at PORSCHE and they told me that they don't repair engines so i tried to repair it.I was searched in romania for parts and i found a man who sold parts of 911/996 engine.i told him my problem and he told me that he made his boxster engine by himself so i asked him if he can repair this engine and he told me YES but he don't know one thing...to set up the distribution because it is a special way."
Get these books:
Porsche 996: Essential Companion, by Adrian Streather
D-483-721-OEM Porsche Factory Workshop Manuals, 16 Volumes, 911 (1999-on)
Available at
http://www.pelicanparts.com/catalog/...TOLbks_pg1.htm
He has been knocking around the forums asking the same Q. How do we help?
http://forums.pelicanparts.com/porsc...911-996-a.html
http://forums.pelicanparts.com/porsc...96-please.html
http://www.renntech.org/forums/index...y-911996-2003/
Old 02-26-2011, 12:46 AM
Pac996
Pac996's Avatar
Running the car out of oil requires all the engine bearings to be replaced or the crank and piston rods have a good chance of failing again. Even the piston cylinders need to be checked and probably honed or cylinder walls replaced. I'm not even sure if you can hone the cylinder walls with the type metal they are.
Sounds like a real lousy time. Good luck.
Old 02-26-2011, 02:21 AM
redridge
redridge's Avatar
here... look.... dont forget the oil this time.
http://www.youtube.com/profile?user=glenn986s#g/u
Old 02-26-2011, 07:48 AM
carrera911/996
Cruisin'
Unhappy
Originally Posted by r1de23
Are you for real?
Sure i checked the dmage parts,the block and pistons are like new,i did,t runed it too damaged the engine so bad.when the pressure oil light shows i have stoped the engine and i went to aporsche service.they gaved me a bad new.they dont repair engines they only change them with one brand new.So i talked to a man wich i orderd in the past some parts for the transminsion box and he told me that he repaired his engine by himself at a boxster and he told me to bring the engine to him.He opend the engine case and he looked in it and he told me that the bearings looks bad and he measured the axle and he told me that has to be changed.also the oil pomps.i changed all these parts and now we get to the final step.to set uop the distribution.i need some specificationb how i need to set it.thanks
Old 02-26-2011, 08:13 AM
Shark Attack
He out of country... Let help the brutha out.... He had the ***** to come and ask, Lets assume he knows a bit what he is doing, Lets just take that for granted and aswner his questions with out telling him it cant be done.... I am sure a lot is lost in translation here
Now who can give this guy the Ign firing order?
Old 02-26-2011, 08:50 AM
Gofishracing
Gofishracing's Avatar
Trial & error. What a concept.
Old 02-26-2011, 11:03 AM
mglobe
The Penguin King
mglobe's Avatar
+1
I have to think that the folks at LNEngineering and/or Flat 6 innovations can help out.
https://www.lnengineering.com/
http://www.flat6innovations.com/
Old 02-26-2011, 01:16 PM
carrera911/996
Cruisin'
i wonder why do you say that?what is wrong with you?i told i did everithing...i changed all the damaged parts....is an engine!!!!the porsche specialist are human too.what is did is that i changed damaged parts and i assambled like they doi put the piston in the block wich is the hardest job i checked the piston and were like new...also the block...the damaged parts were bearings,pomps and the axle and these werent too bad damaged because i have stoped the engine at time when the oil pressure ligh appeared ..i did everithing stept by step but now i am at this final step.Also i went in poland and i have a friend there wich has an 996 3.4 2000 year engine and i made pictures at that crankshaft position from 4-6 cylinders but i need too know if 3.4 is the same as 3.6 engine and if the distribution is settisng as same at 3.4.My engine is 3.6.
Old 02-26-2011, 01:17 PM
carrera911/996
Cruisin'
thanks Kyle for the good words. and thanks for trying help me
Old 02-26-2011, 01:35 PM
Sneaky Pete
Sneaky Pete's Avatar
I wish I could help but the internal workings of the engine are not my strong points. Surely someone will chime in soon.
Quick Reply: SET UP DISTRIBUTION AT MY 911/996 2003 ENGINE PLEASE!!!
