996 Forum 1999-2005
My car is down on power!
Old 04-01-2011, 10:41 AM
Joshg
Joshg's Avatar
Unhappy My car is down on power!
Hi this is my first post here so i'll attach a pic of my car too.
My car is a 98 996 c2. The car has 49k miles and has just had a full service in the last 1000 miles.
I took the car to a dyno dynamics machine to see what power it is, the results were very disappointing. It got 225bhp at the wheels 275bhp at the flywheel
So its basically 25bhp down on a standard car.
The engine is standard apart from a k&n CAI and PSE.
Can anyone suggest anything I could check on my car to work out why its running down on power?
[IMG][
Uploaded with ImageShack.us/IMG]
Old 04-01-2011, 10:47 AM
chsu74
chsu74's Avatar
Beautiful car! Because you have an after market CAI, I would suggest cleaning your MAF sensor. I replace mine every 25 to 30K miles because I get oil on my sensors from 1st gen EVO CAI. I notice a big difference before and after. Fuel filter replacement is also recommended every 60K miles. Plugs and coil packs?
Old 04-01-2011, 11:02 AM
Chris996
Chris996's Avatar
NICE GT3 LOOK AND THE TITANIUM GT3 RIMS.
Old 04-01-2011, 11:03 AM
nick49
nick49's Avatar
10 different dynos = 10 different results
There are no universal standards for dynos, most results I see are optimistic, some tremendously so!
If you seriously think you have a problem, have your car checked by an Indy or Porsche dealer. A quick test drive by a tech will reveal more than your dyno sheet. GL
Old 04-01-2011, 11:08 AM
ivangene
Parts Specialist
ivangene's Avatar
plugs (old wrong ones)
maf (dirty, oiled)
fuel (bad fuel)
fuel filter (dirty, clogged)
CAI (maybe worse than stock)
Dyno set up wrong?
cats (plugged)
mufflers...missing or altered
full diagnostic on cam possitions (one bank off position to the other - cam solenoid)
steering wheel on the wrong side.....
nice looking car
Old 04-01-2011, 11:21 AM
Optical TDI
Optical TDI's Avatar
maf (dirty, oiled)
fuel (bad fuel)
Dyno set up wrong?
cats (plugged)
nice looking car
How does one clean the MAF?
Old 04-01-2011, 11:40 AM
fpena944
fpena944's Avatar
MAF cleaning spray can be found at a local auto parts store. It's real easy to use and helps keep your MAF in best working condition.
Old 04-01-2011, 11:47 AM
Barn996
Barn996's Avatar
Your '98 C2 is certainly a looker! Can't add much to what has been suggested, but can you drive a friends C2 so you can make a seat of the pants evaluation to compare the power of each?
Old 04-01-2011, 11:50 AM
Barn996
Barn996's Avatar
When I had aCEL last year I cleaned my MAF and it cleared the CEL, but only temporarily. A new replacement solved the problem for me. There is a tamper proof torx tool you'll need, other than that it is very easy to do and might be worth your effort. Do a search and you'll get all the specifics.
Old 04-01-2011, 11:52 AM
jumper5836
jumper5836's Avatar
A friend of mine with a 3.4 did timed running pulls with ca on and off. He found it was slower with the ca installed.
Old 04-01-2011, 11:53 AM
Divot
Much missed
Divot's Avatar
There's an easy DIY fix for that.
Old 04-01-2011, 12:02 PM
Joshg
Joshg's Avatar
Thanks for the suggestions keep the coming!
Car had major 48k service at Porsche 1000 miles ago.
plugs (old wrong ones) just replaced at 48k major service
maf (dirty, oiled) Has had a new MAF in the last 500 miles !
fuel (bad fuel) Always ran on uk 99 ron fuel basically the best stuff we can get here.
fuel filter (dirty, clogged) just replaced at 48k major service
CAI (maybe worse than stock) Maybe but I thought it was supposed to add power? I will try car with stock setup back on.
Dyno set up wrong? Other cars on that day were getting good results, Ive heard dyno dynamics is the most reliable and accurate dyno around?
cats (plugged) Not sure what how I could check this?
mufflers...missing or altered standard exhaust/headers with PSE mufflers
full diagnostic on cam possitions (one bank off position to the other - cam solenoid) Would I take it to Porsche to check this out?
Also coil packs would have been changed at the 48k mile service I think.
Because my car is a 98 it has a cable throttle so I have checked to see if it was stretched and not opening the throttle valve fully but it looked ok.
Old 04-01-2011, 12:20 PM
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
not really. Butt dynos are hideously unreliable. A tech might be able to detect a problem with how the car runs, but its rare for someone to notice 10-15 hp missing.
dynos are only are reliable as the information inputted into them. I believe a dyno dynamics is a load bearing dyno, and you need to input the weight of the vehicle. If you get that wrong, it can sway the results. They also tend to show lower results than a dyno jet.
Old 04-01-2011, 12:24 PM
Barn996
Barn996's Avatar
You don't think you'd notice a 25hp reduction as stated by the OP? I do.
Old 04-01-2011, 12:50 PM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,282 Likes on 899 Posts
How did you attain the flywheel numbers? Were they derived from the RWHP values? Few people have an M96 engine dyno (we do! :-)
A normal 3.4 996 makes 240RWHP on my dynojet over and over again..
Quick Reply: My car is down on power!
