996 Forum 1999-2005
Bilsteen PSS10's Installed on my 996 C4S
Old 04-03-2011, 06:15 PM
howardm50
howardm50's Avatar
Default Bilsteen PSS10's Installed on my 996 C4S
Installed PSS10's, Tarett Engineering drop links and GT3-RS sway bars on my 996 C4S.
I dropped about .75" in front and .50" in the rear; but I was most interested in the handling - which is outstanding! The PSS10's really eat up the bumpy city roads around here, and they lock onto the pavement like on rails in the mountain twisties. I'm running 4 clicks in front, 6 in the rear for now; the sway bars are set at the second hole on the front, first (softest) on the rear. I had the alignment done at the "sport" factory setting. Great for daily-driver use so far.
Great upgrade - highly recommended!
Here's a pic, the stance is definitely more agressive... which is a nice bonus. (You can compare to my Avatar pic).
Old 04-03-2011, 06:46 PM
ivangene
Parts Specialist
ivangene's Avatar
see - SO MANY PEOPLE complain about a suspension upgrade being "rough" or hard to drive on a daily basis....it BS isnt it!!
If done right, its way better to go for "more cowbell"
W A Y T O G O - on your upgrades!
Old 04-03-2011, 07:16 PM
howardm50
howardm50's Avatar
From my motorcycle days I learned a more advanced/upgraded suspension can do wonders to smooth out the bumps. That's exactly what I was looking for. I am certain if I turned the rebound/dampening settings all the way up to 10, I'd have a different experience. But that's why I went with adjustable (same as I've done on my bikes).
I feel 10X more "planted" on all surfaces going from stock/OEM M032 "touring" suspension - with 44K miles on it - to the new Bilsteens. The sway bars are just icing on the cake; turns are just sick with very little roll.
I will probably drop the front setting to the first (softest) holes as with the rear; getting a bit of understeer in the second setting at lower speeds (around 40mph). I'll give it a few days though before I mess with it.
PSS10's are about $2000 a set depending on where you get them; Tarett drop links and GT3 sway bars come as a front and rear package from Tarett for about $1400 total for the front and rear setup. Installation will vary depending on what route you take - my local P*Dealer has a great race tech on staff, so I let him do the install and alignment (on his fancy alignment computer/machine).
For my money, I've always felt suspension upgrades are the best investment.
Bilsteen PSS10 Coilovers
Tarett Drop Links & Sway (Anti Roll) Bars
Old 04-03-2011, 07:32 PM
ivangene
Parts Specialist
ivangene's Avatar
+1 for the Tarret GT3 sway/drops... made my car sit flat as a pancake thru turns, night and day differance.
again, nice choice!
Old 04-03-2011, 10:21 PM
Malakas
Malakas's Avatar
Very nice! I'm jealous
Old 04-03-2011, 10:30 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,264 Likes on 793 Posts
[QUOTE=howardm50;8439869]Installed PSS10's, Tarett Engineering drop links and GT3-RS sway bars on my 996 C4S.
[/QUOTE
Which dealer did it? Prestige or Stevenson?
Old 04-04-2011, 12:30 AM
howardm50
howardm50's Avatar
Stevinson. Great work/service as always from them.
Old 04-04-2011, 01:51 AM
francars
francars's Avatar
Very nice upgrade. Sometimes I think I should have gone PSS10s instead of my RoWs. But its not too late right?
Old 04-05-2011, 09:56 PM
Surfer161
Surfer161's Avatar
+1 on the upgrade
surfer161
Old 04-06-2011, 09:49 AM
Optical TDI
Optical TDI's Avatar
What are your alignment specs now?
Old 04-06-2011, 08:42 PM
911mike99
911mike99's Avatar
Default GT3 Wing
You need to put a wing on there now. And that Porsche will rock!
Quick Reply: Bilsteen PSS10's Installed on my 996 C4S
