996 Forum 1999-2005
Stereo (CDR23) stays at "PORSCHE" screen (radio doesn't come on) when turned on
Old 04-29-2011, 11:37 AM
Mister Quickie
Mister Quickie's Avatar
Default Stereo (CDR23) stays at "PORSCHE" screen (radio doesn't come on) when turned on
Usually I just turn the radio on and the PORSCHE screen comes up for a few seconds and then it goes to to the station I preset, no problem.
The other day I played with a couple of the buttons and pushed out one of the CD trays, the radio continued to play but now it doesn't.
I don't think this is related since I believe it played after my aforementioned button experimenting.
This morning I push the dial to turn it on and it just remains at the PORSCHE screen, I turn up the volume and try other pushing and holding button combinations ... nada
Old 04-29-2011, 11:41 AM
Sneaky Pete
Sneaky Pete's Avatar
Have you tried to enter the 4 digit radio code? Maybe with the buttons you were pushing you ended up locking it up?
Old 04-29-2011, 12:01 PM
RF5BPilot
RF5BPilot's Avatar
I have heard that turning the car on and off can help.
Sometimes, alternating pressing the CD button, then the FM button can get it going again.
Mine used to do it more often until I started shutting off the radio before I turned off the car. If I do that, it almost never happens. Almost seemed like the power cycle confused the communication between the radio & the amp.
Old 04-29-2011, 05:40 PM
psamead
psamead's Avatar
Mine also does this every now and then. The fix I use is to turn the head unit off, turn the car off, exit the car and use the remote to lock it then unlock the car, get back in, start the car and finally turn on the head unit. Works every time.
(I also know a great cure for hiccups)
Old 04-29-2011, 08:45 PM
pterfloth
pterfloth's Avatar
Mine did that once when the CD door wasn't closed properly. Have you tried opening and closing it?
Old 04-29-2011, 09:16 PM
zabuch
zabuch's Avatar
TAKE OUT RADIO FUSE IN THE FUSE BOX FOR ABOUT 10 SEC THAT WILL RESET IT
Old 05-01-2011, 01:03 AM
fpb111
fpb111's Avatar
To re-boot the system I have to pull both radio fuses D8 & 9 on my 03 cab
Old 05-02-2011, 01:27 PM
Mister Quickie
I turned the car on
Turned the radio on
Turned the radio off
Turned the car back off
Remembered to turn the radio off before turning the car off going forward
No recurrences since
Thanks for all the help
Old 05-02-2011, 04:47 PM
mavthenav
mavthenav's Avatar
it happens to me every once in a while, have to turn car off , lock it, count to ten , get back in and all is good.
Quick Reply: Stereo (CDR23) stays at "PORSCHE" screen (radio doesn't come on) when turned on
