996 Forum 1999-2005
X-74 suspension question
Old 05-20-2011, 02:19 PM
1fastline
1fastline's Avatar
Default X-74 suspension question
I just had the X-74 suspension kit installed in my 2003 C2. I now can only get -30 min. of camber maxed out in the front. I did not expect alot w/o camber plates or control arms but this does not seem right as usually lowering will net you more. It makes me wonder if the install was done correctly as I think you can get more even with the stock suspension. Thoughts?
Old 05-20-2011, 02:35 PM
Ahsai
Ahsai's Avatar
I have the same setup. The x74 c2 alighment calls for -30 min +/- 15 min front camber. So if you meant -30 min, your alignement is right on. My impression is you don't get much more cambers even with x74.
Old 05-20-2011, 04:00 PM
1fastline
1fastline's Avatar
Thanks for the correction, I did mean -1/2 degree. It is set to the factory specs as you have indicated. I was hoping to get more as I am running r-compounds.
Old 05-20-2011, 06:51 PM
1fastline
1fastline's Avatar
Anybody have their camber settinga after X-74 install?
Old 05-20-2011, 09:39 PM
smackboy1
smackboy1's Avatar
I have my car aligned at F -1 deg R -2 deg without any problems.
Old 05-20-2011, 09:50 PM
Ahsai
Ahsai's Avatar
I have -0.5 deg in the front and -1.7 deg at the rear.
Old 05-20-2011, 09:59 PM
Sneaky Pete
Sneaky Pete's Avatar
I have mine at factory X74 specs. No complaints.
Old 05-20-2011, 11:54 PM
1fastline
1fastline's Avatar
Thanks for the replies. I wouild love to see -1 to -1.5. Does it not seem odd that -.5 is all there is? I thought lowering helped increase camber.
Quick Reply: X-74 suspension question
