996 Forum 1999-2005
Installed a sub need a little help
Old 06-09-2011, 11:21 AM
white99c2
white99c2's Avatar
Default Installed a sub need a little help
The sub is in and really sounds terrific, I still have the factory CDR 210 with all the original 6 Nokia speakers and the 6 channel Nokia amp. I wired the 12V switched hot to the amp from a fuse that gets hot when I turn the key, the amp turns on, works great but not the way I want it to because if I sit in the car listening to the radio I have to have the key turned to power the sub.
I tried to pick up a hot at the amp in the front trunk by my '99 must be different its a Nokia Amp. There is no A7 red/black at my amp. With a test light I have one hot at the amp that works just like the fuse I picked up, key turned-hot, key off-no power.
Can anyone help me out here to locate a hot that will come on when the radio is on and off when the radio is off?
http://www.6speedonline.com/forums/9...rear-subs.html
Old 06-09-2011, 11:23 AM
ivangene
Parts Specialist
ivangene's Avatar
OH... that kind of sub....
I was thinking 6 point
Old 06-10-2011, 08:14 AM
MJP911
MJP911's Avatar
Quick Reply: Installed a sub need a little help
