996 Forum 1999-2005
Clutch issue
Old 11-28-2011, 05:39 PM
cliffhanger
6th Gear
cliffhanger's Avatar
Default Clutch issue
I have a 1999 911 that has a clutch issue. The clutch pedal when push goes to the floor. You can pull the pedal back up and it stays up, but as soon as you go to push it, it goes back to the floor. I was told the clutch runs off the brake system or something like that. Well when I checked the brake fluid was empty. And that would cuase the air in the line. But the hydraulic was still full. I could use all the advice possible before sending it to the shop. Thanks
Old 11-28-2011, 06:40 PM
logray
logray's Avatar
ummmm... well brake fluid in the system is probably a good thing to start with.
It helps to have working master/slave cylinders.
Along with not having any leaks.
And being bled properly.
But aside from that, my guess is, fluid topped off, brakes and clutch bled and you'll be back off in no time.
Here's a DIY if you are interested:
http://pedrosgarage.com/Site_3/Bleed...26_Clutch.html
Old 11-28-2011, 08:25 PM
cliffhanger
6th Gear
Does the brake fluid being low have any effect on the clutch.
Old 11-28-2011, 08:52 PM
logray
logray's Avatar
Certainly. Did you look at that link I provided you. Spells it out pretty clearly...
Old 11-28-2011, 11:20 PM
fpb111
fpb111's Avatar
Try just filling the clutch reservoir.
Old 11-29-2011, 12:02 AM
cliffhanger
6th Gear
Yeah I look and saved the link I just wanted to make sure. The hydraulic fluid was full just the brake fluid wa low.
Quick Reply: Clutch issue
