996 Forum 1999-2005
Die Hard ($159) or Interstate ($175)?
Old 03-12-2012, 01:12 PM
washington dc porsche
washington dc porsche's Avatar
Default Die Hard ($159) or Interstate ($175)?
I'm going to grab one today which do you think is the better?
Old 03-12-2012, 01:31 PM
himself
himself's Avatar
Do a search and you'll find other alternatives. I went to Autozone and got the cheaper battery. It works fine.
https://rennlist.com/forums/996-foru...ch-2011-a.html
-td
Old 03-12-2012, 01:43 PM
chsu74
chsu74's Avatar
cold crank amp is the important spec to compare the different batteries.
Old 03-12-2012, 03:12 PM
scottiemac
scottiemac's Avatar
That sounds like a lot of money. Check around - you should be able to get one for around $100. I can get them for that price - even in Canada.
Old 03-12-2012, 03:24 PM
TomF
TomF's Avatar
$100 is about right. Check around a bit more and save some bucks...
Old 03-12-2012, 04:12 PM
function12
function12's Avatar
Cold cranking amps and warranty are what I always go with. I think you can find a better choice at AutoZone if you have one.
Old 03-12-2012, 04:34 PM
logray
logray's Avatar
I got a walmart battery for around $80, it's been trouble free for more than 3 years.
Old 03-12-2012, 04:40 PM
rpm's S2
rpm's S2's Avatar
My Porsche tech swears by Interstate. I once had an Autozone battery in my 968 that lasted about a week.
Old 03-12-2012, 08:08 PM
tkrtape12
tkrtape12's Avatar
I've always used Interstate never any issues...
Old 03-12-2012, 08:12 PM
Macster
Macster's Avatar
The techs at a dealer I visit once in a while swear by Interstate batteries too. In fact the dealership went away from using the IIRC Moll battery and now use Interstate exclusively.
Word up though: the best Interstate batteries I hear -- from the techs -- are made in Spain. I checked the battery in my car and didn't see any sticker indicating where the battery was made. I haven't had a chance to ask where the made in Spain sticker is so it may be on the side or end of the battery. I didn't bother to remove the battery to see if I could find the sticker. The battery is working just fine and I'm not going to worry about it until it doesn't.
But if you have a chance to look over the battery before you buy it and have it installed...
Sincerely,
Macster.
Old 03-12-2012, 08:17 PM
No HTwo O
No HTwo O's Avatar
I have an Interstate in the Turbo and an AutoZone batter in the Boxster.
You should be able to buy an Interstate (MTP-91) for closer to $120. I've seen them at Costco for <$90. Not sure if this is your size. Check.
Old 03-12-2012, 08:26 PM
Axeman
Axeman's Avatar
I never liked the Interstates and always had bad luck with them. I bought a Bosch at Pep Boys for less than $100 for my wife's 996 last year, seems to be good so far.
My $0.02
Old 03-12-2012, 09:29 PM
RXDOC
RXDOC's Avatar
Bosch Premium Plus Group 49
w/850CCA and 1000CA
some of the best numbers I have seen!
36 month free replacement
96 month pro rated replacement
3 year roadside assistance
About $100 at Pep Boys
Old 03-13-2012, 09:17 AM
Mark I
Mark I's Avatar
+1 on Logray's suggestion. Walmart (at least locally) lists as the proper replacement an H6 size, which has 770 CCA and fits the third bolt hole in & performs identically to the monster sized one I replaced.
Old 03-13-2012, 11:18 PM
930tony
4th Gear
930tony's Avatar
YOU MIGHT LOOK AT OPTIMA MINE WORKS GREAT CAR SITS FOR EVER AND ALLWAYS STARTS
Quick Reply: Die Hard ($159) or Interstate ($175)?
