996 Forum 1999-2005
Bump Steer Correction
Old 03-29-2012, 02:25 PM
Capt. Obvious
Capt. Obvious's Avatar
Received 1,418 Likes on 777 Posts
Default Bump Steer Correction
My C4S is lowered quite a bit (under 25" ground to fender with 19" wheels). As a side effect of this, I'm noticing a significant increase in bump steer. I've always had my cars lowered quite a bit, but this is the first car that I've experienced such a noticeable increase in bump steer with. I did a few searches, but none of the threads I found were very helpful.
After consulting the mighty Google, I did find that a few companies make extended tie rods for these cars (Tarett, GMG, Stomski). Does anyone here have any experience with any of these products? Did they help enough to make them worth the ~$500 investment?
Besides the tie rods, are there other ways I can help reduce the bump steer? I have adjustable camber/caster plates and adjustable sway bar end links up front so most of the suspension geometry can be adjusted.
And no, raising the car is not an option.
Old 03-29-2012, 02:42 PM
SSST
SSST's Avatar
My bump steer improved dramatically when I went to the X73 setup. You've got a lot more going on with you suspension than I do however.
Are you sure it isn't related to the 19" wheels?
Old 03-29-2012, 02:48 PM
jumper5836
jumper5836's Avatar
search on "bump stop"
Lots of reading in the links provided.
https://rennlist.com/forums/996-foru...coilovers.html
Old 03-29-2012, 03:07 PM
Capt. Obvious
Awesome links, thanks. Lucky for me, a good chunk of the problems described in those links don't apply to me since I have the JIC Cross suspension and my suspension is adjusted so I'm not sitting on bump stops (or hitting them as far as I know).
I did see a mention of shimming the steering rack to lower it a bit, so I may look into that as well.
Old 03-29-2012, 03:18 PM
Gonzo911
Rat Balls
Gonzo911's Avatar
Ron Burgundy announces "Anchorman 2" yesterday and you change your avatar? What's up with that?
Old 03-29-2012, 03:24 PM
Capt. Obvious
LOL! I was thinking that as I was changing my avatar this morning. Perhaps I should bring it back...
fpb111
fpb111's Avatar
How did you manage to lower the car and Raise the rack? Isn't the rack attached to the "frame"? Maybe spacers to raise the rack? http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
or tie rod ends that drop the tie rod ends:
http://www.pelicanparts.com/cgi-bin/...0Tie%20Rods%29
996
http://www.pelicanparts.com/cgi-bin/...%30%35%2Don%29
Whichever way you decide to go the rack and tie rod ends need to be in a straight, horizontal line with car "at rest" on the ground.
Old 03-29-2012, 03:34 PM
AudiOn19s
AudiOn19s's Avatar
ERP makes toe arms both front and rear that use spacers at the wheel carriers to correct geometry to minimize bump steer on a lowered car. I've got them front and rear on my GT3
The mounting locations on the regular 996 cars are not very forgiving when you get them pretty low creating alot of toe movement as the suspension goes through it's range of motion. You won't get it all out but you will be able to make it more manageable with the ERP links.
Old 03-29-2012, 03:42 PM
Capt. Obvious
That was one solution until I did a quick image search and realized the way the rack is mounted doesn't allow it to be spaced like that, so that option is out.
Old 03-29-2012, 03:44 PM
Capt. Obvious
Looks like the tie rod ends are the best solution for my situation. Guess I'll have to order a set...
Old 03-29-2012, 05:39 PM
Zookie
Zookie's Avatar
PM Sent
Old 03-29-2012, 10:42 PM
Shark Attack
Shark Attack's Avatar
Whats bump steer?
Old 03-30-2012, 09:53 AM
Zookie
Zookie's Avatar
Originally Posted by Shark Attack
Whats bump steer?
From my understanding its a Action or tendency of a car steering itself when the Suspension Travels when going over a Bump or Uneven Surface on the Road. I guess its more promenint in lowered cars.
Am i correct?
Old 03-30-2012, 10:30 AM
jumper5836
jumper5836's Avatar
I'm not smart but I know how to google.
http://en.wikipedia.org/wiki/Bump_steer
Quick Reply: Bump Steer Correction
