$1400 to replace waterpump!?
#31
Former Vendor
No matter what you do ensure that any and ALL broken pieces of impeller are located before putting the car back into service. Not doing this is a pretty good way to cost yourself several thousand dollars later.
#33
Former Vendor
Match the broken pieces that are found with the pieces missing from the impeller. Most of these end up in the cross flow console on the 4/6 bank of the engine and can require partial disassembly to remove them.
Most every terminally ill 996 or Boxster that we see that has arrived due to an intermix issue has a fresh water pump on it and was installed after the prior pump failed and has been installed by someone that doesn't think about the negative issues related to foreign object debris floating around in the cooling system.
See the August 2012 edition of Excellence Magazine in the Tech Forum section for a full article on the reasons why this is a big deal. I contributed the pics and some other info for that article and its spot on accurate.
#35
Captain Obvious
Super User
Super User
I have a 996.106.101 pump on my project car ('99 996). It was on there when I bought it. So it works on a '99 for sure.
#36
Captain Obvious
Super User
Super User
#37
I had mine replaced in April of this year. Water pump, drive belt,check condition of idler, tension rollers, fill bleed cooling system, $562. My indie paid $360 for new pump.
02 C4 btw
02 C4 btw
#38
I just had mine done at the Porsche dealer...........parts, fluid, and labor.....minus PCCA discount.......$907
Just to throw the numbers out there for what my dealer charged me. I knew it was going to be done right also. Used to go to an indy, had very bad luck with our BMW and Audi there. Dealer works great for me in my situation where I live.
#39
My water pump went recently. Dealer invoice to replace it was just under $1200 (in FL they charge sales tax on the labour as well as parts). I paid nothing however. It was completely covered by my extended warranty...you know, the one certain buffoons insist is a scam that only stupid people would buy
#41
$4600 for 6 years, bumper-to-bumper "exclusionary" not named-item (equivalent to Fedelity Platinum except with no 50,000-mile limit on items that fail from "normal wear"). So far it has reimbursed me $2600 and it still has another 4 1/2 years to go. Given the car is 7 years old now, I have no doubt it will at least break even and most likely more. Every extended warranty I've ever had has done that, sometimes double. So basically for zero net cost I will be covered until the car is 12 yrs old in case of a catastrophic failure like IMS or scored cylindre or such.
#44
Same here,even NAC which covers my Mercedes don't write warranties for Porsche in Florida.
BTW I see a warranty not as what I can get out of it but as a insurance,I also don't hope that my house burns down because I pay a premium
#45
Mine's an early MY05 but I bought the warranty 1,5 years ago, so, same difference I suppose. The dealer offered me a Fidelity Platinum at that time, so I'm surprised you couldn't get one on your '04 a year earlier. That said, you might not have wanted it, as the one they offered me was $8600 I ended up with a similar warranty called Tech Choice Ultra which cost "only" $4600.
