Cracked Head
So if you don't visibly see oil in the coolant or coolant in the oil, what is a good way to monitor for intermix? Oil analysis every time you change your oil? I'm not anxious about it or anything but wouldn't want to drive it to death if it ever does happen.
I sent my head to Costa Mesa R&D/John Edwards. This was back in late 2008 early 2009. Not many shops were doing the fix back then. Back then when I called John as soom as I told him I had a crack and before I told him which headend where, he told me exactly where it would be (inner exhaust spewing seat on cylinder 1). I think this is the most common crack. There is another shop in Athens GA that is advertising in Excellence magazine that it fixes cracked 996 heads. I am sure that Flat 6 has a shop if they don't do them in house.
Not to push it too hard, but if the price of the crack repair has increased (I heard one quote of $800 recently) and you need valve work, etc. in addition to the crack repair, the $1,400 I want for the new head I have is not too bad of a deal.
Carry out a compression and leak down test.. We see a huge portion of intermix cars with cylinder issues from the intermixed oil that has no boundary layer protection. Over 1/2 the cars that we could save have been compromised by being driven to death.
We also see accelerated rod bearing wear from intermix engines. Lots can be told by pulling the sump and cutting the filter open.
I see two cracks in that head. Both are repairable with our regimen. But definitely ensure the remainder of the engine is not compromised.
View from the bottom below. Oil had been drained when I picked this motor up (bought locally off eBay, rolling the dice I know) -- filter was MIA as well. Guy I bought if from mentioned no coolant in oil and no shavings in filter. No signs of intermix when I dropped the pan. HELLA SLUDGE, but no signs of coolant or metal fragments whatsoever.
In my opinion most of these cracks can be avoided altogether if 996 owners would adhere to 5 simple preventatives:
1.Change your Water pump long before it shows signs of failure (especially if your car still has the orignal WP - regardless of year or mileage! - These cars are at least 7 years old now)
2. Invest in the lower temp (160) stat - I don't want to get into an argument of whether it keeps temps lower or not - it does - no need to discuss.
3.Ensure the quality of your coolant and make certain you have the right mix for your region/driving conditions.
4. Make sure all hoses are in decent shape
5. Keep your radiators clean and ensure that all fans are working in both stages.
and then drive the Sh*t out of the car.
BTW, that's my head with the red crack detector all over it in the other Doug's post.
