Help car stalled & won't start
Try to push the throttle full open and start. By doing this, ecu will stop the injectors and try to clear the flood.
It seem's thou, that you have no spark.
Get the ecu codes checked, there might be a problem, even when the cel is not on
hope the fuel you added was 93 octane although one would think half a gallon added to already good gas would be ok. Did you add the lawn mower gas BEFORE or after it started to cut out on you? There is usually grass clippings around thed neck of a lawn mower gas can. Or you may have ran the tank very low and disturbed some **** in the tank which found its way to the carb. Especially with it being a high milage vehicle. There may be some crap in there moreso than a lower milage vehicle. Just a thought.
PS-We don't have distributors.
I had a VERY simular condition recently. The re-juv valve was sticking open and putting a vaccum on the fuel tank. take off the fuel cap, try to start and see what you get. It may toss you a CEL.
When it first stalled. It did try to start for about a second. So I added about 1/2 gal. Of Lawnmower gas. Last night I added 2 more gallons of gas & no start. I did notice the antifreeze was 2 cups low in the overflow. I added Porsche antifreeze. Now it just turns over only. It has 86k miles on it.
+1 on the idea of leaving the fuel cap off and trying to start the car. If the evap valve or canister have failed, this should help.
