996 Forum 1999-2005
Which hose is this?
Old 10-18-2012, 08:21 AM
Invius
Invius's Avatar
Default Which hose is this?
This hose is leaking coolant. From what I can see, there are two of them, one on either side of the engine. The one that is leaking is the driver side. I'm looking for a part number if anyone knows it. This picture is not from my car, but it's an image of the hose that is leaking I found on the interwebs. Any help would be appreciated. More than likely the issue is the water pump, but it doesn't appear that any coolant is leaking down onto it, the issue appears that the hose itself is leaking, and it looks slightly bulged.
As always, thanks!
Old 10-18-2012, 08:45 AM
trendy996
trendy996's Avatar
http://www.ebay.com/itm/Porsche-986-...068cb7&vxp=mtr
Old 10-18-2012, 08:58 AM
Invius
Invius's Avatar
I've got a '99 996 C2, that looks like it's for a 986/987, is it the same, or did I grab the wrong photo off the net?
Old 10-18-2012, 09:44 AM
trendy996
trendy996's Avatar
My apologies
http://www.ebay.com/itm/Porsche-911-...a09270&vxp=mtr
Old 10-18-2012, 09:47 AM
speed rII
speed rII's Avatar
http://www.autoatlanta.com/porsche-p...-05/105-05.php
Part 18, you might need part 32 also.
Old 10-18-2012, 10:02 AM
trendy996
trendy996's Avatar
It is an updated part at the dealership. I bought one from them and didn't have to do anything different with what was on my 99 c2.
Old 10-18-2012, 10:28 AM
ivangene
Parts Specialist
ivangene's Avatar
be careful - if the water pump is leaking it can look like its the hose - water pumps leak out of the center of the pulley
remove the belt and see if it wiggles
Old 10-18-2012, 10:52 AM
Invius
Invius's Avatar
Thanks for the info, that's what I was thinking but wanted some confirmation. Ed, I agree it's more than likely the pump, but I figured for 30 bucks or so, I'd hope against hope and see if it was the hose. As well, the hose does look bulged, so replacing it probably isn't a bad idea anyway.
Old 10-18-2012, 11:45 AM
logray
logray's Avatar
There are two versions of that hose coming out of the pump.
The new one requires a new hard pipe attached to it as well.
The old one (if you can still buy it) should be a direct replacement for whats on your MY 99 car.
Old 10-18-2012, 11:55 AM
trendy996
trendy996's Avatar
Do you know when this hoose was updated? I purchased the updated hose and it didn't require me having to buy the other metal pipe.
Old 10-18-2012, 12:36 PM
logray
logray's Avatar
No sorry I don't know when but I do know the superseded part (replacement for the orig) is different from the orig (which is NLA from Porsche).
It could be just very early 99 models with the old hose style, but all of the 99's I've seen have the old hose style.
It is possible your car already received the "updated hose and hard pipe" at some point during it's service history.
It's easy to see, the difference between the hard pipes. The new one has a nearly 180 degree hook/turn before it goes into the water pump hose. The old one just turns about 90 degrees (or less IIRC).
Old 10-20-2012, 08:42 PM
Shark Attack
Shark Attack's Avatar
Yep been here done this.....
Old 10-21-2012, 11:20 AM
Invius
Invius's Avatar
Won't know for sure until tomorrow, as shipping didn't go out when Suncoast thought it would, so instead of Friday, will get it on Monday.
Shark, did you replace your own pump, or have it done?
Old 10-21-2012, 12:25 PM
ivangene
Parts Specialist
ivangene's Avatar
you can remove the belt from the pulley's and check for "wobble" in the WP in about 5 minutes - would save you waiting twice for the mailperson (PC for mailman)
Kyle changed his own - search his epic thread "going in alone" - he's an Upfixen guru
Old 10-21-2012, 03:44 PM
Invius
Invius's Avatar
No kidding! Just read the post, nothing like doing your IMS on your garage floor, fantastic! Ed, what am I looking for with the wobble? Any lateral movement at all, or more than a few mm's? How much if any movement and I looking for?
Thanks,
DS
Quick Reply: Which hose is this?
