Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-10-2013, 09:25 AM   #1
Ghia
User
Ghia's Avatar
Default LSD, differences between G50 LSD and 996/Boxster S LSD?
Hi all,
I've just bought a 2nd hand LSD to fit into a Boxster S (986) /996 gearbox.
Here are some photos of the LSD I've bought.
Click the image to open in full size.
The casting number on the housing is:
950.332.083.01
Along with this are the following numbers:
SA - 082 - 028 - H
98E2177
Now having done some research, some people would suggest that this is a G50 LSD and some would suggest that it was also fitted into 996/Boxster S gearboxes.
I can't find definitive evidence to say either.
Can anyone help please?
I have the option of sending this back, keeping and selling it on and using it if it will fit my gearbox.
MG
To remove this ad, register today or login if you already are registered!
Ghia is offline   Reply With Quote
Old 01-10-2013, 11:30 AM   #2
Ghia
User
Ghia's Avatar
A little light at the end of the tunnel maybe...
I just checked the output flange part numbers (950.332.209.01) and that is used on both 993 and 996 cars
MG
Old 01-11-2013, 09:34 AM   #3
philooo
philooo's Avatar
I hope you will post pics of the install as I want to have this mod done very soon.
so this is a porsche oem LSD coming from a 996 or boxster ?
Phil
philooo is offline   Reply With Quote
Old 01-11-2013, 11:40 AM   #4
Ghia
User
Ghia's Avatar
This is from a 996 but will be going into a Boxster S gearbox. They share many parts including gear cluster, diff. The diff is mounted on the other side of the diff, reversing the drive for the Boxster.
MG
Old 01-11-2013, 12:45 PM   #5
ltusler
ltusler's Avatar
Do you intend to just install it? Arent there mesurement procedures for the pinion depth and such?
Current:
1999 996 X51 FSI 3.8
Past:
1992 968 Coupe
1988 951
1980 911SC
1964 356C
ltusler is offline   Reply With Quote
Old 01-11-2013, 01:21 PM   #6
Byprodriver
MG
996 & 986 S flanges are retained by circlips only. Earlier flanges bolt to the diff (G50??) I suspect what you have is a G50 diff & flanges. But I am not familiar with aircooled parts. I am guessing you have what you want. If you contact California Motorsports they are great to talk to & can verify what you have. Do yourself a favor & order their billet shift arrester to improve shifting on the Box 6-speed.
Byprodriver is offline   Reply With Quote
Old 01-11-2013, 06:06 PM   #7
Ghia
User
Ghia's Avatar
My understanding was that all the LSD diffs had bolt in flanges but I could be wrong.
Yes the early Boxster S and 996 gearbox flanges are clip in.
I will pull it to pieces and check the condition of the plates etc before installing it. I know that these diffs should only have about 15NM drag when testing. I'll also be interested to see the ramp angles.
MG
Old 02-05-2013, 12:42 PM   #8
Ghia
User
Ghia's Avatar
Well I finally managed to find time to pull the diff apart.
Here's a photo of the stack and ramp angles.
Please excuse the state of it, I haven't cleaned anything yet.
It has 2 friction discs, one of which is missing small section of material so obviously they're past their best.
Can anyone tell me which car this is from and what the ramp angles would suggest with lock-up percentages on and off power?
I am still in the position to say to the seller that it's not what he sold it as... i.e. a 996/986 Boxster S LSD.
Cheers
MG
Old 02-07-2013, 01:05 AM   #9
jrgordonsenior
jrgordonsenior's Avatar
Looks like stock 25/55 ramping to me but I'd call Matt @ Guard. He's got all the right parts to set that diff up correctly....
JR Gordon
99' 3.4/3.6 996
POC- GT3 Champion 2010, 2011
NASA- ST2 So Cal Champion 2010, 2011
Let's not talk about 2012.....
jrgordonsenior is offline   Reply With Quote
Old 02-07-2013, 07:27 PM   #10
Ghia
User
Ghia's Avatar
Well looking on here and on other websites, the casing number suggests a standard 993 LSD so I've started proceedings to return it as it's not going to work well in a Boxster gearbox as I'd end up with 25 lockup on acceleration and 55 on deceleration. Not great
MG
Old 02-08-2013, 12:24 AM   #11
jrgordonsenior
MG
Before you throw that fish back call Matt @ Guard. I believe the 993 and 996 LSD's are one and the same but call him....
And what-the-hell's wrong with a 25/55 diff? If nothing you might want more ramping like 40/60 (cups) or even 50/80 but that's based on your driving style. Nothing wrong with the 25/55 ramping especially for street cars....
JR Gordon
99' 3.4/3.6 996
Old 02-08-2013, 04:56 AM   #12
Ghia
User
Ghia's Avatar
Sorry, I've got it mixed up there.
If I have a 25/55 in a 911, surely fitting this to a Boxster S config would mean the opposite as the diff turns the other way?
So I'd have 55/25..
MG
Old 02-08-2013, 02:39 PM   #13
GTgears
User
GTgears's Avatar
So I'd have 55/25..
MG
Not true. Not only does the ring gear get moved to the other side, but it spins the other way around, making it a zero sum game. Locking factor would remain unchanged installing it into a Boxster.
As you have determined, that is a 993 LSD, but is is 25/65, not 25/55. For a Boxster that would actually be a pretty good set up after you rebuild it. The Boxsters don't like a lot of throttle lock up unless you've done ridiculous things with the power. They have more traction than power, and too much LSD lock and you overdrive the front wheels and get a lot of push. We fought it in Grand Am for a long time repeatedly detuning the LSDs to allow drivers to get on throttle earlier. Even then, proper throttle modulation and not treating it like an on-off switch is key.
If you look carefully, there is one clutch per side, plus that massive spacer. You can remove that spacer and make is a 4 clutch LSD (2 per side). Doesn't really change the nominal lock up, which we usually tie to the ramp angles, but would significantly increase the effectiveness of the unit.
Regards,
Matt
GTgears is offline   Reply With Quote
Old 02-11-2013, 01:51 PM   #14
Ghia
User
Ghia's Avatar
Thanks for the reply Matt.
It's going into a Boxster S gearbox which is inturn being bolted onto a W12 engine with somewhere between 450-500bhp so a fair amount of power.
The question is whether I'm better off returning this unit and just buying a new Quaife from Uk as they're around £790 plus VAT.
Something tells me that by the time I've bought all of the parts from US and shipped them over, it would cost more than buying new.
MG
Old 04-10-2013, 09:57 PM   #15
boxhead
User
Can it be confirmed that the G50 diff is interchangeable with the G86/20 trans. without mods?
boxhead is offline   Reply With Quote
Paid Advertisement
Tags
993, 996, boxster, bsp, clutch, determine, difference, flanges, g50, lsd, make, open, output, porsche, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
