996 Forum 1999-2005
hesitation
Old 01-12-2013, 04:36 PM
jzzzake
jzzzake's Avatar
Default hesitation
In the am, when I start my car, she will start up and idle perfectly, but when I step on the gas, she will bog down, I can hear a slight popping in the engine compartment. If you keep your foot on the throttle, she will stall out. But if you feather the gas until you can move the idle up to around 2500 or 3000 the hesitation and bogging goes away and doesnt come back until you try to start the car. It happens only at initial start up.
Symptoms - bogging down at start up under throttle. slight backfire, hesitation, no check engine light
Parts already replaced - fuel pump, fuel filter, spark plugs,
Aftermarket parts - Headers, K&N cold air kit
Work done - removed and cleaned throttle body, replaced plugs, fuel filter, fuel pump
Any suggestions?
Old 01-12-2013, 05:27 PM
KrazyK
KrazyK's Avatar
Jzzzake, just an observation but it would be helpful if you would post your car info, year, mileage, etc. I assume its some type of 996 or you wouldnt be here. It has a fuel filter you replaced so pre 2002? But, you also say fuel pump so who knows what year you have? Who did the work? When? Symptoms before work done? Stored code(s), may not show CEL?
From what you posted, my WAG is:
1.coil packs
2.other ignition problem
3.injector (doubtful)
4.MAF (more doubtful)
5.AOS (unlikely)
And, also IMHO, the K&N is a red flag, headers another red flag. Oops. Forgot, check for vacuum leaks too.
Old 01-12-2013, 07:56 PM
Macster
Macster's Avatar
Deleted.
Old 01-12-2013, 08:51 PM
Hurdigurdiman
Hurdigurdiman's Avatar
Backfire? Doesn't that indicate a wrong air/fuel mixture? Or maybe the timing is out somehow? Now I have no idea what controls those symtoms on these More modern cars but I could solve it on the old beetles in a flash haha. Then again altering the original to Aftermarket parts - Headers, K&N cold air kit, may effect the performance of the engine. Hell I don't know so I had best shut up. Hope you solve the problem. Are you using the top grade fuel?
Old 01-12-2013, 09:54 PM
Pac996
Pac996's Avatar
When the headers were done did you remove the cats and or O2 sensors? Does the air pump come on at start?
Old 01-12-2013, 10:14 PM
fpb111
fpb111's Avatar
Sounds like lean condition at cold start. Vacuum leak?
Old 01-13-2013, 01:38 PM
mcipseric
mcipseric's Avatar
check your MAF sensor on the intake.
Old 01-13-2013, 01:58 PM
white99c2
white99c2's Avatar
How cold is the temp outside? My car will pull back also as I pull out of the driveway when it's cold outside. When it does I back off the throttle and its dime. Do not rev a cold engine in past 2500-3000 rpm's until the temp gauge gets up to the the 1st line on the gauge. I don't know what year your 911 is but mine is a 99 that first went into service in May of 1998. I go easy on it until the temp is up and then drive it normal. It's a teenager and I am determined to keep it for 6 more years, it will then be a 20 year old car.
Old 01-13-2013, 02:15 PM
jzzzake
jzzzake's Avatar
The car is a 1999 C2. I live in Key West so the mornings are never less than 65 degrees. I did the work myself, as I own a shop here,there are no stored codes, no CEL, always run the best gas, cats and O2 sensors are still there, air pump comes on at start, MAF working prfectly.
Old 01-13-2013, 04:12 PM
ChristopherG
ChristopherG's Avatar
A bad coolant temp sensor messing with the cold start enrichment possibly.
Old 01-13-2013, 09:36 PM
Hurdigurdiman
+1... My sentiments entirely. I have the same year C2.
Quick Reply: hesitation
